#1 _LC0033_
Posted 29 June 2016 - 08:47 PM
I went through possible problems vacuum leaks, timing and mixture, etc and came to a conclusion to fix this problem regarding the 350 Holley it is need to change the carburettor accelerator pump cam these cams come in a kit of different colours and I have found with the standard 202 with 54 size jets the brown coloured cam is needed and works the best this kit was $40.
Just thought I'd let you all know as I am very happy with the conclusion and thought it could be helpful to others
Posted 30 June 2016 - 04:34 AM
#3 _oldjohnno_
Posted 30 June 2016 - 06:01 AM
A couple of the bigger cams including the brown one are meant to be used with a 5cc pump, the 3cc pump with a brown cam will run out of stroke. It'll still work but the pump might eventually work loose.
#4 _LC0033_
Posted 30 June 2016 - 05:20 PM
Thanks for your help. I will check out the pump and see what cc it is
I know the 350 is not the correct carby to be used for a stock motor but i will putting up with it now until we find a stromberg and or do some headwork to the motor.
