The LC 2 door... Quick lick and Flick
103 replies to this topic
#101 Caustic
Caustic
  • 144 posts
  • Name:John
  • Car:LC 2 Door. Hot 202, Celica 5 spd, 3:08...Quick hwy cruiser.
Posted 14 January 2018 - 10:20 AM
Thanks Paul, This weeks project, is trying to fine tune my triples. Only have a couple of pictures with the engine complete,just need to get my head around the mechanical accelerator linkages.The two different pictures show the standard and alloy rocker cover.Perfer the alloy cover, but due to the roller rockers spurting oil directly at the pcv, i get a steady stream of smoke whilst crusing hence the stardard cover.Has anyone had any luck with the pcv breather combo off ebay, that will be my next purchase.cheers all Attached File  20171204_074105-1632x918.jpg   212.54K   2 downloadsAttached File  20171125_190320-1651x929.jpg   209.46K   1 downloads
Edited by Caustic, 14 January 2018 - 10:39 AM.
#102 Com_VC
Com_VC
  • 304 posts
Posted 14 January 2018 - 12:47 PM
Paint looks good :)  Nice colour.  Is that acrylic or 2 pack?
#103 warrenm
warrenm
  • 1,795 posts
  • Car:1972 LJ Torana
Posted 15 January 2018 - 05:19 AM
The alloy covers generally need a thin plate attached under the PCV hole similar to the factory covers.
#104 Caustic
Caustic
  • 144 posts
  • Name:John
Posted 15 January 2018 - 07:05 PM
Hi all, the paint is acrylic with the clear blended into it on the final coats, i think thats what my friend said. I also need to fabricate that factory splash plate inside the alloy cover,then need to find someone to tig weld it into postion,a project for later on.The factory rocker cover works perfect.
Just clarify the rear sway bar post, i used the sway brackets off the vn diff and made my own angle brackets which connects the studs to the end of the sway bar.cheers
Edited by Caustic, 15 January 2018 - 07:12 PM.
