How To Polish Lx Hatch Mouldings?
Posted 24 July 2016 - 02:53 PM
Posted 24 July 2016 - 04:53 PM
Posted 24 July 2016 - 05:05 PM
Silvo Daz that should work
hey gene they have scratches on them mate so not sure if you can sand them or not before trying to polish them....
Posted 24 July 2016 - 05:26 PM
Posted 24 July 2016 - 05:57 PM
There has been heaps of threads/posts on polishing these trims.
They are aluminium trims with silver anodising over.
Polishing anything but very minor marks cannot be done - the scratches are in the anodising and it is very hard - seemingly impervious to polishing.
The anodising needs to be removed using a caustic soda and warm water bath - Youtube is your friend.
Warning - do not leave in the cautsic soda solution for long - monitor it several times - otherwise the solution will eat into and through the metal altogether.
Cheers, TB
Posted 24 July 2016 - 06:01 PM
There was a thread on here recently about them.
They are Anodized Aluminium, and to be done properly would need to have the dings, scratches removed, polished, etc, and be reanodized, the anodizing protects the aluminium and stops it corroding, but it also makes it difficult to repair.
You need to talk to a place that does anodozing, I know they can strip the colour from stuff, and recolour it, but in the process you usually loose the bright sheen it usually has and it ends up a mat finish, but maybe there are other ways to approach it.
The anodizing process effects the surface of the aluminium on a molecular level, so I image this surface would need to be removed before the trim could be repaired and re-anodized.
Posted 24 July 2016 - 06:07 PM
cheers for the replys guys looks like they will need to be done by the experts
Posted 24 July 2016 - 07:30 PM
https://m.facebook.c...coursemoulding/
Posted 24 July 2016 - 09:06 PM
I need to get all mine done as well, check out these guys on Facebook they do some pretty good work.
cheers mate
Posted 26 July 2016 - 08:09 PM
Be sitting down when you get the quote - the work is amazing but far, far from cheap.
If you want to have a go yourself then have a look at sites like these:
http://www.secondcha.../public/665.cfm
http://autobodystore...d-aluminum-trim
http://www.jalopyjou...um-trim.154089/
And videos like this:
https://www.youtube....h?v=PenOoZDMFew
https://www.youtube....h?v=4BxFn0111Bk
https://www.youtube....h?v=6__RekE1dCo
Cheers, TB
Posted 26 July 2016 - 08:33 PM
Cheers, TB
Cheers for the links TB i knew if i got the pro's to do it i would be raped so to speak lol.....
Posted 26 July 2016 - 08:54 PM
Bend over Daz lol
Posted 27 July 2016 - 09:20 AM
Raped and piliged
Bend over Daz lol
Not again haha....
