6 litre in lx wa
12 replies to this topic
#1 _project lx_
_project lx_
Posted 07 August 2016 - 08:51 PM
Does anyone have a registered and engineered lx with a 6 litre in wa ?
I believe the weight of the vehicle comes into it as to litre size cheers
#2 Ice
  • 15,103 posts
Posted 07 August 2016 - 09:00 PM
Dont think its allowed in W.A. to many cubes
Ring DPI they will tell you yes or no
#3 _project lx_
_project lx_
Posted 07 August 2016 - 09:35 PM
Ok will check dpi I thought the rule was 5x the tare of the vehicle mine is 1271 on old rego papers or is there a bit more to it ?
#4 Ice
  • 15,103 posts
Posted 07 August 2016 - 09:51 PM
Pretty sure it so many cubic inches only but do check
#5 ls2lxhatch
  • 5,329 posts
Posted 07 August 2016 - 09:54 PM
There are plenty of registered 6L LH/LX Toranas in WA.
Even using  just 1204 kg you can have 1204 x 5 = 6020 cc. The actual heaviest LX is 1306 kg x 5 = 6530 cc.
http://ls2lxhatch.co...cifications.htm
I have approval in principal from the WA DPI for an LS2 in a LX hatch. I still have not finished the car so it has not been through engineering yet. A friend of has a L98 engineered in his LX hatch.
Edited by ls2lxhatch, 07 August 2016 - 09:55 PM.
#6 Ice
  • 15,103 posts
Posted 07 August 2016 - 09:57 PM
Really is that after or before the rule changes Andy
#7 _project lx_
_project lx_
Posted 07 August 2016 - 10:01 PM
Thanks ls2lxhatch for that I have private messaged you I was wondering if I could get your number to give you a call cheers
#8 ls2lxhatch
  • 5,329 posts
Posted 08 August 2016 - 01:05 AM
Which rule changes are you refering to?
The current NCOP is 2011.
My first application for a LS2 in a LX Torana was approved in 11th Aug 2006.
I submitted a second application in 2015 because several components had changed. I also figured the original approval may have expired. The second application was approved in 7th Aug 2015. (Oddly enough, one year today)
#9 _project lx_
_project lx_
Posted 08 August 2016 - 07:40 PM
Yep spoke to an engineer today and it is ok to do 6litre is yours drive by wire throttle body ls2lxhatch
#10 ls2lxhatch
  • 5,329 posts
Posted 10 August 2016 - 02:34 AM
Yes. I have a 2005 LS2 6MC with stock LS2 throttle body, knock sensors, cam angle sensor, crank reluctor and E40 ECM.
#11 8BALL
8BALL
  • 187 posts
  • Name:..
  • Car:yep
Posted 10 August 2016 - 09:54 AM
Engineers in SA said if you have $$$ pretty much anything goes.
I could fit an 8 litre into a HB if i wanted.
aslong as i did exactly what they said etc.
lately ive been seeing quite a few mental cars being legally registered with huge engine and tyre combo's etc.
#12 _Brenno304_
_Brenno304_
Posted 11 July 2018 - 02:19 PM
Hi all,
currently going through the same process myself, vsb 14 hasn't changed since 2011, but licencing centres have told me 180kw per tonne max, unless engineer certified. Does anyone know an engineer that will sign off on an L77 6 litre in W.A??
cheers in advance.
p.s - 2 engineers I've spoken to have said same thing and wont sign off... they said 235kw max for a torana based on 1306kg
#13 bat 53
bat 53
  • 477 posts
  • Name:albert
  • Car:lc gtr
Posted 12 July 2018 - 11:37 AM
even if an engineer signs off on it  it still wont be excepted
had a 6lt in a vk engineer said ok but engineering said no
ls1 only with full engine measuring before being past
sam rossi is the engineer
cheers  bat
