Fitting front retractable seat belts LJ 2 door.
Inertia reel belts
8 replies to this topic
#1 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 14 August 2016 - 07:28 PM
I have just fitted new inertia reel retractable seat belts to the front of the yellow terror. This is something I also had to do to my LS powered LJ to get street rod certification.
It's very easy to do and the belts are much nicer than the originals for those not fussed about originality.
You will need very little in the way of tools.
Attached File  image.jpeg   170.39K   27 downloads
I used two of these. The 300 mm stalk for the buckle puts it at the point of my hip.
Attached File  image.jpeg   170.15K   12 downloads
You can just see where the anchor point is under the trim.
Attached File  image.jpeg   203.83K   15 downloads
Pop a pointy object through to get started.
Attached File  image.jpeg   49.83K   11 downloads
Four little radial snips with the scissors is enough to open it up.
#2 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 14 August 2016 - 07:58 PM
Attached File  image.jpeg   84.46K   16 downloads
Fit this anchor point first. Let the reel dangle so you can see where to drill the hole to mount it. The hole will need to be directly vertically below the anchor point above. Check that you can strip belt from the reel in the position you chose. Of course you will need to remove the rear seat!
Attached File  image.jpeg   194.09K   14 downloads
This is where the hole should be height wise, just below the upper margin of the factory sealant strip. As you can see you will need to cut out a portion of the trim panel at the mounting point.
Attached File  image.jpeg   161.43K   14 downloads
Hole drilled!
#3 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 14 August 2016 - 08:11 PM
Now the slightly tricky bit.
You will need to make a new anchor point. There are various documents available through VicRoads on this subject, other states may vary. Fortunately all the mounting bolts are the same thread as Holden 7/16 wheel studs. As such, a wheel nut welded to a suitable size and thickness piece of steel plate will suffice. Cut plate to size, drill appropriate size hole, weld nut to plate and you are done.
Attached File  image.jpeg   274.35K   12 downloads
The real tricky part is sliding the plate through the circular port above your new hole without dropping it into the body cavity...
I find my fingers are too big to do this as a one step procedure with the reel so I get it set without the reel and pop the bolt in to keep it safe.
Attached File  image.jpeg   298.56K   14 downloads
Plate secured with bolt.
#4 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 14 August 2016 - 08:28 PM
Now you can stabilise the plate from behind with a single finger, remove the bolt, assemble the reel, bolt and washer with your spare hand and reinsert the bolt and reel together. Don't drop anything!
Attached File  image.jpeg   132.45K   13 downloads
All bolted up. Check that the belt returns evenly to the reel without binding. Some fine adjustment may be required to get it spot on.
Mine has had harnesses in it and finding the holes can be hard. The mounting hole for the seatbelt stalks was very hard to feel through the carpet. I got around this by poking through a sharp wire from the underside.
Attached File  image.jpeg   226.35K   9 downloads
My sharpened wire poker.
Attached File  image.jpeg   171.59K   7 downloads
Stalks bolted down.
#5 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 14 August 2016 - 08:36 PM
Attached File  image.jpeg   146.36K   12 downloads
All finished!
#6 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 14 August 2016 - 08:38 PM
Attached File  image.jpeg   152.44K   11 downloads
#7 _LS2 Hatch_
_LS2 Hatch_
Posted 14 August 2016 - 09:42 PM
Thanks for the step by step instructional.
I gather you don't have a rear seat, but can a rear seat be fitted once it has been completed?
#8 _LHSL308_
_LHSL308_
Posted 14 August 2016 - 09:57 PM
Nice work Doug. I suggest admin throws this up as a sticky.
#9 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 14 August 2016 - 11:44 PM
Attached File  image.jpeg   120.2K   9 downloads
Oops, I forgot to add:
Finish off by refitting your unmodified rear seat. If you put the reel where shown it doesn't foul on the seat when fitted. All works as intended.
The belts vary astonishingly in price between suppliers. Aim for $90 each.
