I have a Yella Terra low comp head on my bench at the moment with chambers measuring 55cc.
Now from what I can gather 55cc is pretty standard for a low comp.(most probably got surfaced at YT and that's it)
I am looking at increasing the compression ratio and was wondering if there is a calculation (or rule of thumb) that you can do to work out volume of the chamber versus how much material to remove.
Due to the odd shape of the chamber I would imagine that calculating volume would be a bit difficult but I am sure this has been done a million times before and some one should be able to say yeah .040 thou off will reduce chamber to 50cc etc.
The motor is still in the car and flat pistons are .040 thou down the bores from TDC so not going in that direction but don't want to rip a heap out of the head and then render it no good for other blocks that may have been zero decked.
From what I can calculate current comp is around 8.5:1 and looking to get as close to 10:1 as possible.
