LC washer bottle and hose holes missing!
Posted 27 August 2016 - 08:07 PM
He welded up all the wiring harness holes and the mounting holes for the washer bottle, and I think he has welded up the hole for the washer bottle hoses. Obviously was going for the clean look but I'm going an original look.
See pic below looks like I also have an extra small hole above the wiring harness hole.
Does anyone know if this is factory and if so what the purpose of it is?
Looking inside and it appears that they plated and filled the washer bottle hose hole.
Is someone able to please measure the positioning of the washer bottle hose firewall hole and the opening size / diameter that would help me a lot? I want to run the original style pump hoses for the washer bottle.
Can someone please measure the location of the washer bottle mount holes?
If someone can give me some guidance before I hit it with a drill and hole saw it would be much appreciated.
Steve.
Posted 27 August 2016 - 08:20 PM
What you call the wiring harness hole is actually the hole for the brake pedal pushrod (power assisted brakes) and the hole above is for the top mounting bolt on the booster mounting & relay bracket assy
Posted 27 August 2016 - 09:22 PM
Regards
Col
Posted 27 August 2016 - 10:55 PM
Posted 27 August 2016 - 11:52 PM
If anyone has a pic of the two screw holes for the washer bottle that would help a lot.
Posted 28 August 2016 - 12:10 AM
hole in inner guard and then under washer
bottle to hold it there.the 2 screws are
plenty though
Edited by madtoranajzedded, 28 August 2016 - 12:10 AM.
Posted 28 August 2016 - 12:15 AM
I'm also in the process of sorting out my wiring harness. The car didn't come with one so making one good harness based on a standard LC one with modifications for the GTR dash. I had a good look at the harness and did not notice this singles black wire is it an LJ thing?
Posted 28 August 2016 - 12:18 AM
Posted 28 August 2016 - 12:22 AM
Posted 28 August 2016 - 12:27 AM
Also guys I noticed there is another small hole the other side of the booster with a single wire coming out of it. Does anyone know what this wire is for?
You mean the wire shown coming through the choke cable hole in RallyRed's GTR firewall pic?
Non original wire. LC GTR had a thermally operated auto choke. No choke cable, no power wire.
Edited by S pack, 28 August 2016 - 12:27 AM.
Posted 28 August 2016 - 12:33 AM
holes for you and gromet hole tomorrow
have you the wiper motor wiring hole steve
Posted 28 August 2016 - 12:36 AM
No holes for wiper motor wiring Maz.
Posted 28 August 2016 - 12:42 AM
spose you want the hole measurements where
they are on guards too lol for the wiring ☺
Edited by madtoranajzedded, 28 August 2016 - 12:43 AM.
Posted 28 August 2016 - 01:15 AM
Thanks Maz if you get a chance to measure that would be great.
Steve.
Posted 28 August 2016 - 07:07 AM
Posted 28 August 2016 - 02:33 PM
harness holes and the wiper motor reservior.
they are pretty close i never done the second
hole i will let you get it level in the using
Your bottle 😊.All measures are to middle of holes..whats your measurement col roughly to
first hole.
Heres some
20160828_135354.jpg 568.51K 6 downloads
Edited by madtoranajzedded, 28 August 2016 - 02:42 PM.
Posted 28 August 2016 - 02:47 PM
20160828_141015.jpg 745.85K 8 downloads
Edited by madtoranajzedded, 28 August 2016 - 02:53 PM.
Posted 28 August 2016 - 02:56 PM
Posted 28 August 2016 - 03:06 PM
Hi Maz, I don't follow what you mean by wiper wiring hole. There are no holes in the upper dash panel or the firewall for the wiper motor wiring.
Oh, I can see it now with my glasses on. You mean the heater cable hole?
BTW, what car was the above pic and measurements taken on. LJ by the looks of it.
Edited by S pack, 28 August 2016 - 03:12 PM.
#21
Posted 28 August 2016 - 03:14 PM
Which wiring was hidden and wiper motor
wiring came out of that hole.so its been
enlarged..bugger me.i will do it again on
the big block this time
#22
Posted 28 August 2016 - 03:18 PM
Great save Dave i took those out of the lj
The hole on the LJ hasn't been enlarged. 19mm dia would be correct for the LJ. LC is different.
#23
Posted 28 August 2016 - 03:29 PM
Hole is about 8mm
Pic
20160828_152754.jpg 673.91K 8 downloads
Edited by madtoranajzedded, 28 August 2016 - 03:30 PM.
#24
Posted 28 August 2016 - 03:48 PM
To accommodate the different cable attachment to the heater box control on the LJ.
#25
Posted 28 August 2016 - 05:18 PM
Maz you are an absolute star! I cannot thank you enough for the trouble you have gone to, to help me. You have gone above and beyond. You even took off your clips to measure. Mate I owe you big time, and have taken out the guess work for me
Haven't posted any updates for a while to my build thread, have been plugging away over the past few months and will add a post with the end result of the drilling and fitting of the harness when it's all done.
http://www.gmh-toran...r-build/page-7?
Steve.
