SS HATCHBACK chamois door trim question.
19 replies to this topic
#1 MRGMH
MRGMH
  • 228 posts
  • Name:Torana
  • Car:LJ
Posted 29 September 2016 - 04:03 PM
I'm looking at SS Seats and door trims in chamois.
I have a question regarding the door trim pockets. Are they black at the bottom like the photo or did they also come in chamois coloured carpet?
Thanks
#2 hanra
  • 10,832 posts
Posted 29 September 2016 - 04:24 PM
What is your Trim Code? What colour is your floor carpet supposed to be?
#3 yel327
  • 13,081 posts
Posted 29 September 2016 - 04:30 PM
The trim code will tell you if it is Chamois/Black or Chamois/Covert. Chamois/Covert is where you normally find Covert carpet although I think one of the Chamois trims used Chamois carpet according to Norm's book. So is it 60A, 60B, 60V, 60X or 60Y? Most LX will have Chamois/Black which are the 60A and 60B trims but some early cars used HJ/LH trim which are the V and X trims. You may but unlikely find a 60Y trim on early LX SLR/SS which I think is the one with Chamois carpet in Norm's book but I question this as it should be Covert from my research. You may also find a re-introduction of V, X and Y trim at HZ release in LX which goes back to HJ colour combos but I don't think Chamois (60) style trims are affected in SLR or SS, only SL appears to revert to 60Y. At least according to the changes to the LX, TC and HZ order procedure colour and trim combination charts issued in Bulletin D27 on August 19 1977.
Edited by yel327, 29 September 2016 - 04:36 PM.
#4 MRGMH
MRGMH
  • 228 posts
  • Name:Torana
  • Car:LJ
Posted 29 September 2016 - 04:36 PM
My trim is 60A so the photo posted is correct for that code? Chamois and black carpet?
#5 yel327
  • 13,081 posts
Posted 29 September 2016 - 04:39 PM
Yes, if the vinyl is Chamois and not Beige. I say this as 60A in HJ/HX can mean Beige/Black or Chamois/Black depending upon the lux level - in a Holden it is Beige, but in Kingswood it is Chamois. If the trim-maker has reproed from the wrong sample it will be wrong. When you see new samples side by side the difference is obvious.
Best bet is to get a late LX parts catalogue or Norm's Torana Tough book which both tell what the colour of each bit is.
Edited by yel327, 29 September 2016 - 04:45 PM.
#6 yel327
  • 13,081 posts
Posted 29 September 2016 - 05:02 PM
Here are some scans. On the scanner it is harder to pick between the Beige and Chamois, but look at the 67 vinyl, the Brown and the Tan are more obvious. In the flesh the 60 colour is as easy to pick.
I also included the cloth insert Chamois Chevron (goes in 60B), but yours being 60A is straight chamois with the Chamois 319 insert material.
Edit - i'll have to attach the picture from another PC. Here you go.
Attached File  img-160929163008.pdf   987.03K   27 downloads
Edited by yel327, 29 September 2016 - 05:10 PM.
#7 MRGMH
MRGMH
  • 228 posts
  • Name:Torana
  • Car:LJ
Posted 29 September 2016 - 06:01 PM
Thanks mate above and beyond with your reponse. I've had various trimmers send me samples and all are correct chamois. It's a tad "dirtier" looking than the beige.
Samples. Larger one is NOS NYLEX
#8 dattoman
  • 16,470 posts
Posted 29 September 2016 - 08:35 PM
60A is chamois with the black carpet at the bottom just like mine
#9 arrimar
arrimar
  • 3,121 posts
Posted 29 September 2016 - 09:46 PM
Ever heard of 60W? There are handwritten notations throughout an LH parts book I have for 60W and 18W.
#10 yel327
  • 13,081 posts
Posted 30 September 2016 - 06:40 AM
That is the bench seat Holden trim in HJ Holden and Belmont. I have a feeling they are just plain vinyl trim in LH as 18V and 60V in an LH S has an insert I believe, so the plain trim gets the next letter. I think the last of the Gpaks have 18W trim. I think the 60W is beige though and 60V is Chamois.
#11 arrimar
arrimar
  • 3,121 posts
Posted 30 September 2016 - 08:04 AM
That solves that thanks.
The W notations are against door trims only.
#12 hanra
  • 10,832 posts
Posted 30 September 2016 - 08:35 AM
I thought the -XXW trim had a wood grain insert panel up the top of it?
#13 yel327
  • 13,081 posts
Posted 30 September 2016 - 08:37 AM
Have a look in Norm's book in the LH trim section, you can see the seat inserts in the 18V and 60V trim for S, and W trims with no insert and different vinyl tone come in later in 1975
Did any S get the woodgrain? I though that was SL and up only.
#14 hanra
  • 10,832 posts
Posted 30 September 2016 - 08:39 AM
http://picclick.com....2637258182.html
#15 dattoman
  • 16,470 posts
Posted 30 September 2016 - 09:05 AM
My LH SL has the wood
62V I think from memory
#16 arrimar
arrimar
  • 3,121 posts
Posted 30 September 2016 - 09:43 AM
Did any S get the woodgrain? I thought that was SL and up only.
No woodgrain on S to my knowledge.
#17 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 20 October 2016 - 05:17 PM
Chamois carpet, never ever heard of a car with it. Nor seen one.
Can someone post a pic for curiosity?
#18 hanra
  • 10,832 posts
Posted 20 October 2016 - 06:39 PM
My -60Y should have covert carport. Buckskin is apparently the closest.
#19 yel327
  • 13,081 posts
Posted 20 October 2016 - 08:02 PM
I question it too, but Norm has it so the info has come from somewhere.
#20 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 21 October 2016 - 06:51 PM
For sure, he has dug up some pretty interesting left field stuff.
Awesome book.
