355 engine breather help
25 replies to this topic
#1 _76lxJAS_
_76lxJAS_
Posted 12 October 2016 - 02:56 PM
Can anyone tell me should the breather tank be sealed with a cap or vent with a air filter like pictured.
Please explain why for either if possible.
#2 IMORAL
IMORAL
    Bored
  • 2,567 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 12 October 2016 - 03:30 PM
Nice bay Jason
Is that a vacuum line running to the catch can?
#3 _76lxJAS_
_76lxJAS_
Posted 12 October 2016 - 04:01 PM
Cheers thank mate.
Many of hour's and late nights went into that bay.
Yep vacuum with a pcv fitted and the 2 lines 1 from each rocker cover.
I'm unsure if it should be a sealed can or breath with the filter on it as it had already?
Seems pointless that the breather would be sucking clean air through from the filter and that it is a bit fumey. If it was a sealed unit there would be no fumes and the vac would be sucking theses fumes and re burning them?
#4 gtrboyy
gtrboyy
  • 3,133 posts
Posted 12 October 2016 - 06:56 PM
To have it like that pcv valve would go top no filter.
Will work fine as long as engine is not heavy breather.
Edited by gtrboyy, 12 October 2016 - 06:58 PM.
#5 _76lxJAS_
_76lxJAS_
Posted 12 October 2016 - 07:13 PM
So I'm am better of taking the filter off and capping it to seal the catch can?
Will this pressurize anything?
#6 ozyozyozy
ozyozyozy
  • 944 posts
Posted 12 October 2016 - 08:44 PM
The catch can should be vented to atmosphere, to be legal for the road needs to vent into air cleaner assembly.
If that is a vacuum line to the catch can, its too big, only need something small or else the engine wont idle properly as its not sucking through the carby.
The reason they fit a vacuum line to the catch tank is to reduce the steam/vapour that occurs in the catch can, its not essential, may just smell a little oily when opening the bonnet.
#7 _76lxJAS_
_76lxJAS_
Posted 13 October 2016 - 12:04 AM
The vac line does run to the bottom vac port on the carby base plate?
Engine idles fine no issues at all there?
So the filter at the top should have a line the runs to the air cleaner that makes more sense that way the smoke/fumes would be getting sucked somewhere and reburnt. Now the question is leave it as is or connect a line to the airfilter?
#8 gtrboyy
gtrboyy
  • 3,133 posts
Posted 13 October 2016 - 09:26 PM
Sounds kinda wrong man if goes to vac port for carby although usually base of throttle body on efi v8 if google search it
Pcv on carby cars normally go to fitting side or base of aircleaner.
Shouldn't pressurise as long as engine not got excessive blowby..check/drain it once in a while.
Most people just use catchcan with filter no pcv.
vac port bit usually for charcoal canister suck out fumes...2 types of charcoal cannisters I think.Assuming was done to copy efi setup due to vn heads.
#9 dron
dron
  • 126 posts
  • Name:Darren
  • Car:UC
Posted 25 March 2017 - 04:41 PM
May be an older thread but here goes. The way the engin venterlation should work is the pcv draws fumes out of the cank case and the line from the aircleaner supplyes clean air to the crank case. This reduces the chance of fuel vapour building up in the crank case and therfor reducing the risk of a crank case exploshion.
If the vack line on the catch can has a pcv on it and is then conected to the rocker cover on the other side of the catch can,  the can should NOT be vented. the OTHER ROCKERCOVER should be vented giving you an air inlet and an outlet for the fumes. The inlet should go to the air cleaner and be drawing filtered air.
Edited by dron, 25 March 2017 - 04:49 PM.
#10 Punchy
Punchy
  • 172 posts
  • Name:Scott McCulloch
  • Car:77' Lx Hatch
Posted 29 March 2017 - 03:22 PM
this is a 50 year old concern.
in short. A pcv vale system promotes a 'negative' pressure environment to the crankcase to evacuate it and meet emissions requirements.
Negative pressure means vacuum.  The engine maintains the vacuum by relying on air signal via the port at the carburettor  base plate or spacer plate port, then connected to the PCV valve and to the rocker cover ( generally). The engine attempts to negate the negative vacuum just by normal operation with  gas blow-by via pistons and rings. With the pistons and crank flogging around in there you also get air shift. In high performance engine ( read prostock and similar - in particularly aspirated engines ) creating a negative pressure area diminishes the density of any air in the crank case this reducing windage and promoted oil control. ( Remember the oil Holden Gemini vacuum pumps that were belt driven.. Was all the rage back in the ninety's to naughties onwards to fit one to get cheap high negative pressure in the engine. )
Pro's
1. Promote the above negative pressure to the engine and sucks that smelly shit vapour ( burning oil and contaminants and the like into the manifold to be re-burnt - meet emission requirements.
Win !
2. If your gaskets are shit its only going to suck in a bit of air affecting the state of tune and stops the oil hopefully running out your 15 year old ( or older) rear main seal
3. Negative pressure in a gravity environment will help displace oil back to the sump. hence helps with the oil in the top end issue. ( bit of thought for the geeks out there)
Cons'
If you have a heavy breathing engine - worn rings or is supercharged,  a pcv valve system most likely with not cope enough ( read not enough air being displaced) to maintain negative pressure and its going to go positive under the loud pedal. And burst at the seems anyways one day so fix the underlying issue of bypass.
In short Seal that filter off and use the PCV for how it was intended - your at best only going to have between 10' to 20 in' of vacuum inside the engine... really healthy standard or mild cam engine - big cams will vary greatly
#11 _76lxJAS_
_76lxJAS_
Posted 29 March 2017 - 06:41 PM
Are u saying do away with that catch can and filter? Or just block off the cans filter? The can has a pcv fitted to it to suck out the fumes etc in it. Feed from both rocker covers.
#12 _Painter_Josh_
_Painter_Josh_
Posted 10 April 2017 - 05:50 AM
Legally your catch can shouldnt vent to the atmosphere. Interesting idea running the open lines to the can and then a pcv on the can. You need a breather on the rocker cover to allow air to draw into the engine, then oil feeds to a sealed (no breather) catch can and back to the manifold inlet.
If running a vented catch can you dont generally run it back to the manifold but not legal as fumes vent to the atmosphere.
I had run a catch can inline from my pcv off the rocker cover to the manifold but thinking my lines were too small as the engines not surging oil but the pcv was pulling oil up and through so just running twin breathers for the time being... not legal but doing the job.
#13 _NVR_ANUF_
_NVR_ANUF_
Posted 21 July 2018 - 07:39 PM
l looked for a thread on this. Ive just had 355 rebuilt and noticed there is a lot of "vapour" coming out of catch can. Mine is just plumbed from rocker cover to the can. one line from each cover. No PCV etc. (i know all the legalities etc it vents to atmosphere and technically shouldn't)
So two questions how much is too much vapour?
and will the amount vapour change with weather. ie on a cold rainy day will there be a little more than on a warm day?
TIA
#14 koalasprint
koalasprint
  • 295 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 23 July 2018 - 12:42 PM
At idle I would hope to see no vapour coming out of a fresh motor. Maybe it isn't run in yet?
#15 _NVR_ANUF_
_NVR_ANUF_
Posted 23 July 2018 - 03:04 PM
Motor is new, has done dyno time and maybe 500km's
#16 RallyRed
  • 7,833 posts
Posted 23 July 2018 - 06:07 PM
TIA
I am not expert at all, but could offer the following.
We have a newly built LS2 out to 408 ci. Twin Turbo , BIG vent hoses from tappet covers to a temporary can, until we get back to it.
No hoses from can to anything.  No oil comes out of hoses at all, just vapour.
I think it may be different for a boosted motor, as the inlet manifold is pressurised rather than at vacuum.
When recently dyno'd, I commented on the amount of ""vapour"" coming out...the dyno guy who is a specialist in the these engines, said he was totally unconcerned by it. Normal.
He has commented and offered advise on lots of stuff, so I took it as a genuine comment that it was not of concern.....but it does stink.( fuelly)
#17 76lxhatch
  • 7,150 posts
Posted 23 July 2018 - 06:46 PM
Without the PCV you don't have much choice, you will have vapour coming out because its the only exit for crankcase pressure. Make sure the lines are big.
#18 rexy
rexy
  • 3,584 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 23 July 2018 - 06:57 PM
My old pro stroke built 355 was nicknamed “puffing billy” when it was run in on the dyno (by someone else).
Went reasonably well until it grenaded a couple of thousand Kay’s later.
#19 ozyozyozy
ozyozyozy
  • 944 posts
Posted 23 July 2018 - 09:01 PM
You will get some, the vapour is condensation aswell.
Builds up under the tops of rocker covers and in the breather hoses themselves.
Depends on rpm for breather size.
Most dont run big enough breathers
#20 _NVR_ANUF_
_NVR_ANUF_
Posted 28 July 2018 - 09:39 PM
Cheers guys, appreciate the feedback. I'll keep an eye on it and see if it gets any worse etc.
#21 _NVR_ANUF_
_NVR_ANUF_
Posted 30 July 2018 - 06:36 PM
interesting today, first time i've driven car since the first post. Much warmer day, less moisture in the air and the vapour from the can was far less noticeable
#22 Orange SS
Orange SS
  • 523 posts
  • Car:1976 LX SS Hatch
Posted 01 August 2018 - 09:39 AM
Sorry for the thread steal but I have a question about crank case pressure in my fresh 355.
I have a vac u pan system for ventilation connected from the front of both rocker covers(the same as NVR_ANUF's pic above) but the oil dipstick pops out which is dripping oil on the exhaust.
my questions:
1) Do I require a vent to allow fresh air back into the engine - if so where should I install one? the oil filler? remove one of the vac u pan hoses and install a vent on it?
2) Is there a way to check the vac u pan system is working / check pressure build up in the engine?
#23 ozyozyozy
ozyozyozy
  • 944 posts
Posted 01 August 2018 - 07:59 PM
I have played with dry sumps that pull vacuum.
I found and is hard also to find info, under cranking on start up the pumps dont turn fast enough to pull vacuum so crankcase pressure is created.
also if doing a full rpm run then shut the throttle eg gear change or end of drag run, they create pressure.
So the fix, have done this to a few cars, run a one way valve that blows off crankcase pressure, the spring needs to be light to do this, can buy these easy enough.
When the pumps pull vacuum the valve shits to allow it.
#24 warrenm
warrenm
  • 2,104 posts
  • Car:1972 LJ Torana
Posted 01 August 2018 - 11:50 PM
The vacu-pan system is supposed to create a "Vacuum" in the engine, you'll find that the dip stick is pushing out on deceleration(throttle off) Attach a spring from the dip stick to the dip stick tube to prevent the stick pushing out.
#25 Orange SS
Orange SS
  • 523 posts
Posted 02 August 2018 - 07:40 AM
warrenm - I had thought that putting a spring or similar on the dipstick is just a masking the problem as there shouldn't be pressure build up like that with a vac u pan as that is why its been installed.
My engine has no breather on the rocker covers, only the 2 vac u pan connections at the front and I was tempted to only have 1 of the vac u pan lines and install a breather on the other to allow fresh air to be drawn in when required. Can anyone tell me if this is a good/bad idea?
