What numbers should be on the carby tags for 9/72 Adelaide xu1
68 replies to this topic
#1 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 26 November 2016 - 08:34 PM
Hi What number are on the carby tags for 9/72 Adelaide xu1
#2 _Skapinad_
_Skapinad_
Posted 26 November 2016 - 09:20 PM
I got some off Brad Merrick. Send him your build date and he will supply correctly numbered tags... I can't recall what they were for a 9/72...
#3 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 26 November 2016 - 09:54 PM
Thanks skap, we'll see if anyone else pipes in as well.
#4 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 26 November 2016 - 10:42 PM
Hi Gary
Mine car is a 10/72 Adelaide. All three brass tags are 2393 over 3547. I have no reason to suspect that they are not original to the car.
Bazza
#5 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 27 November 2016 - 12:04 AM
Cheers Bazza
#6 frash da bucket
frash da bucket
  • 1,890 posts
Posted 29 November 2016 - 02:18 PM
Hi Gary,
Mine is a 9/72,Has original carby tags,
2216 - 3547.
Regards John.
#7 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 29 November 2016 - 08:40 PM
Brisbane John? My Brisbane car has those (1) 2216/3547 (2) 2217/3547 (3) 2216/3547 said car is 2392 2393 2392 im pretty shore, both middle carbs different number
#8 frash da bucket
frash da bucket
  • 1,890 posts
Posted 30 November 2016 - 12:11 AM
Yes it is Gary.
You know my car.
You fitted that H pattern sticker in 2002,at bathurst.
Has Danny got the same ones as mine too.
Regards John.
#9 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 30 November 2016 - 06:51 PM
Hi John, no mate his is the Adelaide car, he looked for you at the Canberra torana show. Said he didn't see you or pop's though. My memory isn't that good anymore John, i can remember doing it, but i couldn't remember if it was a Brisbane car sorry mate. That time has gone so fast, Gary.
#10 frash da bucket
frash da bucket
  • 1,890 posts
Posted 30 November 2016 - 09:52 PM
Hi Gary,
I couldn't go to canberra, live in qld now.
I do agree with has gone too fast.
I know Danny's is a Adelaide car,must ring him.
Regards John.
#11 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 01 December 2016 - 07:27 PM
Welcome to sunny Qld mate ! Don't forget he's on silly daylight saving stuff.
#12 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 23 January 2017 - 01:08 PM
Hi Gary
To answer your question correctly we need to determine which batch of carbies you have on your 9/72 Adelaide built LJ XU-1.......
Frashes car has the 3rd batch of carbies used in 1972, these have the brass tag 2216. The 4th and 5th batch of carbies used in 1972 have the letters " TC " stamped into the face. The 4th batch of carbies " TC " were generally used on some 8/72 & 9/72 Adelaide built LJ XU-1,s and have the brass tag 2293, while the 5th and final batch of carbies for 1972 have the brass tag 2393 and are generally found on 11/72 LJ XU-1,s and some very early 2/73 LJ XU-1,s.
Attached File  thumbnail_image1.jpg   40.56K   1 downloads
053FD68E9A8747DB844CC64D35883152_zpsvwxa
#13 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 23 January 2017 - 04:15 PM
Baz
In 1972 & 1973 there were a total of 8 batches of 175 CD Strombergs used on the LJ XU-1,s. They are in order from January 1972 through to September 1973.
1404
2056
2216
2293 ( TC )
2393 ( TC )
2383 ( TCX )
3017 ( TCX )
3133 ( TCX )
Baz, Can you break the code ? ? ?
#14 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 23 January 2017 - 05:11 PM
Hi
A number of years ago II bought some carby parts from Gower & Lee in the UK (the worldwide distributor for these carbys and parts), I asked them about the numbers on the tags - their response was " The part numbers on the brass tag relate to the build specification of the carburettor".
I understand from this, that the numbers are only for identification purposes.
Bazza
#15 _Agent 34_
_Agent 34_
Posted 23 January 2017 - 05:47 PM
so does that mean that whilst they are practically the same carburetor body there is a small variance to the internal parts  and hence they needed to give a new tag to the build of the carburetor which left there manufacturing facility.
I assume that there MAY BE A  manufacturing change ( which i am not aware of in the style of the body )
as this was a controlled operation it sort of makes sense that the tags defines the internal parts, needles jets etc
Ps i don't own a xu and have not looked in depth at the tags on the xu1 but could the above make sense as too why there is changes ?
G
#16 S pack
  • 15,538 posts
Posted 23 January 2017 - 05:53 PM
G
There are two code numbers on the tags. The top number is the assembly date code. The bottom number is the model application code.
#17 _Agent 34_
_Agent 34_
Posted 23 January 2017 - 05:56 PM
Im going to the shed to check a set i have stored - thanks Dave. ill report back
#18 _Agent 34_
_Agent 34_
Posted 23 January 2017 - 06:10 PM
there is no tags, but on the face of all three  they are 226t
thats not on the above list ?
Edited by Agent 34, 23 January 2017 - 06:12 PM.
#19 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 January 2017 - 07:21 PM
I think you might not be on the mark Dave, as mine are by memory 2216 front 2217 middle & 2216 back & the Adelaide xu1 in the question has different number in the middle with the 2 end tags the same as well, more like a linkage set up to me as the middle pull rod is different, Gary.
#20 S pack
  • 15,538 posts
Posted 23 January 2017 - 07:33 PM
Hi Gary, no problem mate.
I always thought the upper number on those tags was the assembly date, happy to be corrected.
Basically the only difference in a set of carbs is the front carby has the brass vac advance port tube fitting and the other two have a brass hex head plug screwed into the port.
Dave.
Edited by S pack, 23 January 2017 - 07:38 PM.
#21 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 January 2017 - 07:50 PM
+ the pull rods with the top adjustment point mate ! Gary.
#22 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 January 2017 - 08:01 PM
Hi Dave, that's what makes sense to me mate, I have seen a few sets that way. I would assume that the 3547 ect was the jetting ect, Gary.
#23 S pack
  • 15,538 posts
Posted 23 January 2017 - 08:13 PM
I think you will find the two adjustable and one fixed length throttle pull rods are part of the throttle linkage assy not part of the carburetor assy as it came from Zenith.
#24 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 23 January 2017 - 09:05 PM
Grantly, the above list is a list of brass tag numbers, they are actually a date, yours has no brass tags. HOWEVER it sounds to me like you have a matching set of genuine 8/72 or 9/72 Bathurst carbies. The brass tags on them if they had brass tags should be 2216-3547, the 3rd batch of carbies used from August 1972. Now all that is left to do is verify the cast dates under the fuel bowl. Should be either 4/72 or 5/72.         GOLD
949 = 3521 Rubber Fuel Lines
226 = 3547 Metal Fuel Lines
#25 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 January 2017 - 09:13 PM
4/72 A 110 on my 9/72 brisbane built xu1 carbies inside the fuel bowl, Gary.
