What numbers should be on the carby tags for 9/72 Adelaide xu1
#26
Posted 23 January 2017 - 09:23 PM
#27
Posted 23 January 2017 - 09:30 PM
Gary, I believe the date code is year/week of the year/day of the week
ie: 2216 = 1972/ 21st week of the year/ 6th day of the week.
#29
Posted 23 January 2017 - 11:08 PM
#30
Posted 23 January 2017 - 11:34 PM
Edited by S pack, 23 January 2017 - 11:51 PM.
#31
Posted 24 January 2017 - 01:16 AM
calendar-1972.png 125.21K 6 downloads
January 1972
Day 1 : Saturday
Day 2 : Sunday
Day 3 : Monday
Day 4 : Tuesday
Day 5 : Wednesday
Day 6 : Thursday
Day 7 : Friday
#32
Posted 24 January 2017 - 01:34 AM
2216 = Thursday 25-5-1972
2293 = Monday 17-7-1972
2393 = Monday 25-9-1972
#33 _ChaosWeaver_
Posted 24 January 2017 - 07:02 AM
Just looked at mine, all 3 are..... 1404 / 3521 949 TA ..
#34
Posted 24 January 2017 - 07:50 AM
January 1972
Day 1 : Saturday
Day 2 : Sunday
Day 3 : Monday
Day 4 : Tuesday
Day 5 : Wednesday
Day 6 : Thursday
Day 7 : Friday
Saturday is not the 1st day of the week.
The format is the day of the week, which resets back to 1 on the first day of the following week.
Edited by S pack, 24 January 2017 - 07:53 AM.
#35
Posted 24 January 2017 - 10:20 AM
#36
Posted 24 January 2017 - 10:41 AM
2216 = Friday 12th of may 1972
2293 = Tuesday 4th of July 1972
2393 = Tuesday 12th September 1972
Happy to be corrected, but if you count the weeks properly and use Sunday as the 1st day of the week, that's what i got
Gary. Put up a calendar Ian if you like & we can work yours out.
#37
Posted 24 January 2017 - 10:45 AM
Hi Ian
These are the 1st batch of 175 CD Stromberg carbies used in 1972, 949/3521 = Rubber Fuel Lines
These can be found on the initial 200 1/72, 2/72 LJ XU-1,s and also the 100 3/72 LJ XU-1,s. From very late April 1972 GMH started with there 2nd batch of carbies, being 226/3547 Metal Fuel lines, Brass tag reading 2056/3547.
Gary
Over the years I have come across 4 different dates on your batch of carbies, the 3rd batch. They are as follows :
2214/3547
2215/3547
2216/3547
2217/3547
The 2216/3547 being the most common...........
#38
Posted 25 January 2017 - 07:59 AM
Hi What number are on the carby tags for 9/72 Adelaide xu1
thumbnail_image1.jpg 40.56K 2 downloads
#39
Posted 28 January 2017 - 12:02 PM
After doing some surfing there appears to be 2 companies producing reproduction carby tags. Brad at XU-1 Heaven and Mick at Torana Restoration Parts and Accessories. Here are the tags and table from Torana Restoration Parts and Accessories. They all but nailed it, though there are a couple of mistakes 31 = week is one, should read 13 = week plus they have missed a batch of carbies, and got the 2383 and 2393 around the wrong way which is understandable.........
Posted 28 January 2017 - 12:37 PM
Over the decades looking at LJ cars that still had the original tags two things have stood out to me .
1 - the top tag numbers are not all the same - for example 3134 [ vac carb ] , and 3133 for carbs two and three .
2 - The stamping positions of both top and bottom sets of numbers of each tag vary within the tag borders
Dead easy to spot repro tags cause they stick out like dogs balls.
So many cars missing tags end up having identical triplet tags .
#41
Posted 28 January 2017 - 01:04 PM
2217 [vac carb ] , 2216 for carbs two and three would be a correct tag set in my book.
2393 [vac carb ] , 2392 for carbs two and three also correct tag set .
#42
Posted 28 January 2017 - 01:45 PM
Sorry - I stuffed my own tag numbers up.
3133 [ VAC CARB ] , 3134 CARBS TWO AND THREE .
#43
Posted 28 January 2017 - 04:24 PM
This certainly was the case for the 200 2/71 and 200 3/71 and 4/71 LC XU-1,s though it was the type that was used and not the date.
3380/3381
048 = 1970 48th week
Torana3.jpg 74.21K 2 downloads
I cant ever recall ever seeing anything but a 1404 or a 2056, I'm not saying they don't exsist, just that I have never seen any ! ! !
A 1404 to compare :
1404 1.jpg 115.02K 3 downloads
1404 2 (2).JPG 71.43K 1 downloads
When the repos get a bit of age to them I don't think they look to bad, certainly better than nothing.............
#44
Posted 28 January 2017 - 04:59 PM
True , better than nothing .
As far as I am aware the forum member flogging carb tags on here just bought someones left over stock before they stut up shop.
AC DELCO from memory.
#45 _ChaosWeaver_
#46 _ChaosWeaver_
#47
Posted 28 January 2017 - 07:26 PM
Kockum, the last 5/73 cyan blue that sold at Shannons, Sydney had two different tags 3017/3547 and 3023/3547 as did the purr pull 4/73 that sold at Shannons Melbourne. hhmmm
#49
Posted 28 January 2017 - 07:53 PM
Hi Kockum,
All 3 of mine are 2216 -3547,are original tags,one of the tags broke,still have it,and fiited one of those repo ones off,Mick from the hunter valley torana club, has the smaller 47,like in the above photo's.
Fly again xu-1 has seen my carby tags many times over the years.
Regards John.
