Lh starts in reverse
4 replies to this topic
#1 _Torantula_
_Torantula_
Posted 07 December 2016 - 12:25 PM
Hey guys I'm new just a question I have swapped my 3 on the tree to 4 on floor but can seem to stop it from starting in reverse. It won't start in drive but will in reverse can anyone help?
#2 yel327
  • 13,081 posts
Posted 07 December 2016 - 12:57 PM
You've swapped from a 3spd column shift manual to a 4spd floor shift? Where does drive come into it? Just put your foot on the clutch and you can start in any gear?
#3 Bigfella237
  • 4,371 posts
Posted 07 December 2016 - 01:49 PM
Considering "It won't start in drive" I'm guessing we're talking about a column-shift automatic rather than "3 on the tree"?
The inhibitor switch probably just needs adjustment, you should be able to loosen the mounting screws and slide it forward or backward until the starter will only work in Park or Neutral.
P.S. First post... Welcome to the forum Ben
#4 Balfizar
Balfizar
  • 461 posts
Posted 07 December 2016 - 01:52 PM
Its not school holiday time again is it?
#5 ben23
ben23
  • 236 posts
  • Name:Ben
  • Car:'77 LX 2850 sedan
Posted 09 December 2016 - 11:32 AM
Sounds like you have picked up the wrong wires at the inhibitor plug and run them to your ignition switch, you need the green and pink wires for reverse not the two purple ones. You just need to bridge those.
