202 remote oil pump setups
#1 _Last-Rites_
Posted 07 December 2016 - 01:09 PM
Due to a continuing lack of oil pressure I'm looking for external oil pump setups. Does anyone know of a kit that can be purchased. Had a quick look but nothing I can find.
Cheers Matt
Posted 07 December 2016 - 02:01 PM
The lack of oil pressure may not be fixed by using a different (external) pump!
What is the motor? fresh rebuild? old tired paddock basher? Stock? gazillion HP V8 eater?
The standard pump in good condition does very well in most stock to mild motors.
If your pumps in good condition your problem is gunna be else where & fitting some external job aint gunna fix it!
Need more info on your motor & exactly what testing have you done to think you need something else ?
#3 _Last-Rites_
Posted 07 December 2016 - 03:46 PM
Posted 07 December 2016 - 03:55 PM
Unless you do a dry sump set up
So the engine builders can't recommend a suitable oilling set up?
#5 _Bomber Watson_
Posted 07 December 2016 - 04:43 PM
Time to strip it back down and check it all properly I recon.
Up to and including .004" on the mains shouldnt cause any dramas.
#6 _Agent 34_
Posted 07 December 2016 - 04:52 PM
mechanical gauge - on the oil pump ?
just make sure that the gauge is reading right first.
#7 _hutch_
Posted 07 December 2016 - 04:57 PM
Posted 07 December 2016 - 05:15 PM
Posted 07 December 2016 - 07:07 PM
So what's the goods on the existing oil pump. You may have mentioned it in your other thread but I can't remember.
Posted 07 December 2016 - 10:18 PM
^^^^^ what he said
Posted 07 December 2016 - 10:51 PM
is a dry sump remote?
I see some dry sumps are lower down.
Posted 08 December 2016 - 12:02 AM
Posted 08 December 2016 - 05:14 AM
They cant give you clearances and tell you
- 'its good'
Yet clearly by all the threads its not good.
So nobody else wastes their hard earned $$$$$ with them, who are they?
#14 _Bomber Watson_
Posted 08 December 2016 - 09:10 AM
Sounds like a typical builder.
#15 _73LJWhiteSL_
Posted 08 December 2016 - 09:39 AM
If you are just using the standard oil gauge in the cluster the often are not very accurate. Mine would drop to zero when the LJ was hot at idle, but when I connected the mechanical gauge to the oil pump using a T piece I still have 9 or 10PSI when hot idling. Definitely check this first to ensure you are seeing accurate figures, but if the mechanical gauge is showing very low I'd be going back to the builder or as others have said tearing it down.
#16 _datpsi_
Posted 08 December 2016 - 09:49 AM
Posted 08 December 2016 - 03:16 PM
I tend to agree that you should investigate further as to a) whether you are in fact getting low pressure- ie verify readings and 2) check the actual clearances.
My engine is built for nitrous but holds 20psi at idle, using JP HV pump.
I would be looking closer at the source of the problem rather than bandaiding it. If it was an old dunger I would probably bandaid it but this is a new motor, that presumably you have paid good money for, hence you dont want to accept anything less than 'right' IMHO.
#18 _Last-Rites_
Posted 13 December 2016 - 07:28 PM
Just read all the posts and honestly I'm pulling it out and sending it to the builder. We pulled the pump apart and it's fine. The pick up and sump are brand new ASR.
Myself and a mechanic built the motor but the problem is with the machining. We think he has machined the mains to 0.012 etc instead of the 010 bearings I bought. He couldn't give us crush clearances and when we gave him measurements he said it would be ok.
If u want to know who they are u can come see me in person. Until then I'm going to give him a chance to rectify the situation. I have spent in excess of $15k on this build and don't particularly want to see it going down the toilet by me mentioning who he is online.
Thanks for ur help. I'll try to keep u updated.
#19 _Last-Rites_
Posted 13 December 2016 - 07:38 PM
Posted 13 December 2016 - 07:39 PM
Hi Matt
Just trying to get my head around this. So the engine builder did the machining and yourself and the mechanic assembled the crank, rods, pistons, rings etc into the block?
#21
Posted 13 December 2016 - 07:42 PM
By the way one of the measurements for a crush on a main cap was over 0.074 and that was just touching the plastigauge.
Holy crap, 74 thousands of an inch (0.074) would be like sticking your dick in a bucket.
#22 _Inj gtr202_
Posted 13 December 2016 - 08:13 PM
I'm guessing 0.074mm ie. Closer to 0.003"
#23
Posted 13 December 2016 - 08:27 PM
Ahhhh, that makes more sense thanks. I always tend to think in imperial measurements for mechanical tolerances & clearances etc.
He does say the bearings he bought are 010's which should be .010" u/s
#24 _Last-Rites_
Posted 13 December 2016 - 08:53 PM
Hi Matt
He had the bottom end assembled but admitted he never checked the clearances. He stripped it back out before giving it back to me.
He also told me he fitted the girdle (he didn't fit it properly), also that he fitted the sump and pickup with the girdle on (which he didn't) as both items required me to make new items to make them fit or in the case of the sump had to be returned for a full custom modification. Was great paying another $400 in freight.
#25
Posted 14 December 2016 - 05:57 AM
I think you are on the right track mate. Dont name and shame at this stage- give them a chance to fix the problem.
Also, as a side note, never blindly trust that what a machiner has done is correct and accurate- they make mistakes just like the rest of us. One of the problems with machiners though, is that they also can seem ultra confident and tell you that ' it is right, your wrong, our work is always good, ive never had a problem in 30 years blablabla'... but in honesty, i have seen some MASSIVE issues caused by poor machining, or mistakes made during machining.
Ive had a block returned with the pistons sitting 2mm above the deck (I kid you not... and when I mentioned this issue, they said they had dummied it up ). As soon as they saw this in person though, they were quite embarrassed... They massively over decked the block (big night out the night before maybe??). I have also seen them over bore/hone to way beyond clearances (triple to 4 times the spec I ASKED for).
Every one of my engines that I have built has every bearing clearance measured with plastiguage, every cylinder measured to ensure its at the spec I specify and so on. Its an extra 15-20 minutes during a build, but think about how much money and time you spend building the whole thing, taking engine out and putting it back in, etc etc etc...
