happy new year;
my money is on the tail shaft, but then again if the tail shaft has not had an issue before and nothing has changed engine wise then i may come back to the plugs.
pull a 1/4 - 1'2 up out of the carbies main jet if they are CD's and see if the change to the #ibration's is still there - you may get a cough on acceleration =- this is a lean of the mixture after this the re# range and the tourque of the engine should continue
at least this will tell you if the problem is a fouled plug or a rich mixture.- PS it should change the #ibration range based on the air fuel mixture somewhat if this is the cause.
that plug looks way to rich in the picture, and for street dri#ing I'd run it a bit lean and suffer the cough, on a big foot stamp on the accelerator
Id also check plug temperature range - take the frOckkkkkking thing out and also run the temperature up, start in first - pull about 5500, pull a " wazza special " and side step the box and cut second, hold id till you feel you wallet about to open then see if third is an option for the old girl !!!
if third is an option then gi#e it the berried and smile
if your running CD's or SU's then this is an easier TUNE FIX if your running webbers then your path is a little bit longer - talk to JdLj
the torque of the engine is only passed through the tailshaft under load,, any other time it's maintaining it's inertia position, the torque and the load will depend on the deflection of the tailshaft's harmonics.
hence my money is on the tail shaft which may ha#e had a touch up at some stage - check for lumps bumps and worn uni#ersals -
Ps - stay close to the source of what is shaking the car.
G
