WB Ute V8 Clutch cable Issues
32 replies to this topic
#26 S pack
  • 15,538 posts
Posted 19 August 2017 - 01:11 PM
Also found this from EXEDY, which says it's for M20 & M21 but talks about V6 engines, seems a tad confusing...
attachicon.gifTNE.pdf
Those ^^^ are the adjustment procedures for a pull type cable clutch.
#27 Cook
Cook
  • 1,504 posts
Posted 19 August 2017 - 01:22 PM
Well I'm please to hear that Dave.  So I can cross off one of my problems then.  Unfortunately it's not the main one. LOL Cheers Ron
#28 Cook
Cook
  • 1,504 posts
Posted 19 August 2017 - 02:54 PM
The good news is, I can now get it into all gears.  Only problem is that the clutch pedal is way up on where it should be. I can't adjust it back any further as the fork hits the top of the opening in the bellhousing so   I suspect I would have to adjust the pivot ball to rectify that but I can't get any leverage on it.  I think my best bet is now to take it to a professional to look over and adjust as it should be.  At least I feel like I have solved the problem, within reason.  Thanks again to all for your help and advice. Cheers Ron
Edited by Cook, 19 August 2017 - 02:55 PM.
#29 S pack
  • 15,538 posts
Posted 19 August 2017 - 03:00 PM
Still sounds to me like you have a 6 cyl clutch pedal but I'll cross my fingers it is as simple as adjusting the clutch fork pivot ball.
Edited by S pack, 19 August 2017 - 03:07 PM.
#30 Cook
Cook
  • 1,504 posts
Posted 19 August 2017 - 07:08 PM
Dave, you would know better than I, but I did have a 6cyl one in the car originally and the one I bought from Restos is supposedly for V8 and it does have a longer hook on it but a bit difficult to compare exactly.  I bet my fingers are crossed more than yours lol.  Cheers Ron
#31 _LS1 Taxi_
_LS1 Taxi_
Posted 19 August 2017 - 09:32 PM
Hi Ron,
Concept is simple. Cable moves the same at pedal as thrust bearing.
Figure out how much throw you need at the bearing to actuate....then measure how much movement you get at the pedal through its travel.
You'll figure out quickly if it's an adjustment thing. You might have a combo (thrust bearing, pedal, fork) that won't work together for whatever reason but it's possible to modify things. Die grinder on bellhousing or modify fork or modify pedal hook.
Not sure of your location in Melb?
#32 rodomo
  • 17,999 posts
Posted 19 August 2017 - 11:43 PM
Dunno about that? Might be a ratio change? cable link - pivot - thrust?
#33 _LS1 Taxi_
_LS1 Taxi_
Posted 19 August 2017 - 11:50 PM
Correct. Poor wording.
The cable movement at the pedal is the same as the cable movement at the FORK.
