Alternator rebuild & difference
17 replies to this topic
#1 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 January 2017 - 08:11 PM
Hi guy's, I'm just Wondering about the difference between a std bosch lj torana alternator & the bosch xu1 alternator, apart from the pulley. Is the part number only on the sticker ? If someone has some photos of things i should look at date marks ect. What would be the best parts to use in it, fag or Timken bearings ect. Would be nice to see an exploded view, if possible, it's to suit a 9/72 brisbane xu1. Are they still 35 amp alternators ? Gary.
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 04 January 2017 - 10:54 PM
Gary
Looking at the LJ Parts Catalogue, it appears that the Bosch alternators for that period are the same on the 6 cylinders. 35 amp 13.5 volts. The "Generator Assembly" has a different part number to the others, but that would be because it includes the larger pulley. The only additional individual components mentioned specifically for the XU-1 are the pulley, 2 braces (instead of 1), and a bolt with extra length to accommodate the extra length.
Bazza
#3 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 January 2017 - 11:03 PM
Thanks for your reply Baz, that makes things easier, zinc fan & black pulley i believe on the brisbane car ? Gary.
#4 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 January 2017 - 11:07 PM
Hi Baz, i forgot to ask could you please tell me what the part number for the 9/72 xu1 alternator is mate ? Gary.
#5 gtrboyy
gtrboyy
  • 3,136 posts
Posted 04 January 2017 - 11:10 PM
Assume they'd be similar except maybe detail changes that xu1 had.
Jump up to 55 amp if you as they all bolt up the same
#6 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 January 2017 - 11:51 PM
I'm trying to restore the car to original mate, the casing & The external regulator anyway ! It has a lj alternator i just wanted to get it right. Gary.
#7 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 05 January 2017 - 06:42 AM
The part number for the "Generator Assembly (Bosch) XU-1 eng.) is 2820452. That is largely irrelevant, because the part number would only appear on the spare part packaging.
I can only assume that the original would have had the zinc plated fan and black pulley.
Bazza
#8 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 05 January 2017 - 06:23 PM
Baz, would you possibly know the part number on the sticker, Like the 9 120 060 661 ect, by any chance mate ? Hope that's not being a pain, thanks Gary.
#9 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 05 January 2017 - 06:49 PM
I have a 69 LC s Alternator here if some pictures would help?
#10 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 05 January 2017 - 07:02 PM
Hi Tony
The casing changed with the LJ - no longer had the black plastic grill thing on the back
Bazza
#11 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 05 January 2017 - 07:07 PM
Ok, no problems. Cheers.
#12 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 05 January 2017 - 07:38 PM
9 120 060 679 is the correct one. Mine has the same number but ends with 677. I was on it when I got it and it works fine.
Bazza
#13 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 05 January 2017 - 09:26 PM
Thanks Bazza, much appreciated I'll see if anyone does the stickers ! Gary.
#14 Rockoz
Rockoz
  • 3,964 posts
  • Name:Rob
Posted 06 January 2017 - 07:14 AM
From my memories from back in the day there were 2 different alternators fitted to Holdens.
One was Bosch the other was Lucas.
Without the knowledge of the rivet counters back then, I could find no reason for which was fitted to what.
But working at a mates Service Station from the mid 70s I changed many of them.
Always used Lucas Exchange alternators.
Was a big thing when the ones with the inbuilt regulator came on the market.
Also rebuilt a few myself.
Be very careful removing the bearings especially the rear one.
You dont want to move the slip rings at all.
If you do you will more than likely break the wiring to the rings and render the unit useless.
Check the diodes.
Best to remove one leg of the diode from the circuit before testing.
Should be 9 of them to test.
1 faulty one will cause dramas.
#15 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 06 January 2017 - 09:11 PM
Thanks Rob, i might get some bits checked over by the auto sparky, as i do the job, anyone else apart from Brad do the new 3" pulley, does anyone know ? Gary.
#16 arrimar
arrimar
  • 3,121 posts
Posted 07 January 2017 - 12:51 PM
What is a 9 120 060 673 alternator from?
#17 _xu150_
_xu150_
Posted 27 September 2018 - 08:04 PM
What alternator should be on a 11/1972 build XU1. When did they go from external to internal regulators on the LJ.
#18 Shiney005
  • 9,033 posts
  • Car:Toyota Mirai
Posted 28 September 2018 - 02:37 PM
Brisbane Bosch?? ....  Melbourne Lucas?? I only ask because it seems most L34s had the Lucas. Do you know if yours is original Arrimar?
