ticking/rattling traumatic?
#1 _oikurtman_
Posted 09 August 2006 - 07:54 PM
Shifts fine and all gears work no worries now, no more shudder. But, there seems to be a ticking noise coming from the tunnel somewhere, and when i really put my foot down there is a rattle. could this be the auto?
My next guesses are a stretched timing chain hitting the cover? (if that's possible?)
Or maybe an exhaust leak? the exhaust has just been done aswell. I dunno anything about autos...
Posted 09 August 2006 - 08:56 PM
secondly check for loose or cracked flex plate.
#3 _Jewboy_
Posted 09 August 2006 - 09:28 PM
#4 _oikurtman_
Posted 09 August 2006 - 09:31 PM
Edited by oikurtman, 09 August 2006 - 09:36 PM.
Posted 09 August 2006 - 09:56 PM
were the bolts torqued up.
was or is the flex plate checked for cracking.
is the starter fowling.
to check start and remove the starter and drive.
for some reason ive found certine starters not fitting 100%
#6 _oikurtman_
Posted 10 August 2006 - 08:53 AM
cheers.
#7 _oikurtman_
Posted 31 August 2006 - 06:42 PM
No exhaust leaks.
Pulled starter motor out and checked. No probs there.
Pulled inspection cover off and checked flex plate for cracking. All good.
Gave coverter bolts an extra reef with the 9/16.
Put it all back together and it didn't seem too bad. Over the next 5 minutes it gradually got worse and ended up just how it was before.
Any ideas? Or should i just send it back to the guy who built the auto?
#8 _Chamois hatch_
Posted 01 September 2006 - 04:32 PM
john
#9 _oikurtman_
Posted 01 September 2006 - 07:16 PM
I asked my auto guy about it and he said it sholdn't be anything to do with the auto. it's going in on monday coz the box is leaking but he reckons it might be the starter.
I pulled starter out today and put it back in. same thing as yesterday. fine for about 5 mins then gradually gets worse (rattle, ticking is always there).
#10 _oikurtman_
Posted 04 September 2006 - 01:26 PM
Posted 04 September 2006 - 04:05 PM
anyway always start any engine diagnosis with ensuring the engine has been correctly tuned.
Posted 04 September 2006 - 05:53 PM
#13 _oikurtman_
Posted 05 September 2006 - 08:49 PM
with the bonnet open and the engine running, there seems to be a ticking sound coming from the passenger side rocker cover. i'm guessing this might be causing the rattle when i put my foot down. tappets? rockers? lifters?
#14 _Aidan_
Posted 12 September 2006 - 12:03 PM
