Choosing my Cam
10 replies to this topic
#1 _LH1900_
_LH1900_
Posted 20 January 2017 - 07:14 PM
Hey guys, would like some opinions on what cam to go for for my 202. I'll start with the motor..
10.6:1 comp
YT Roller Rockers
Triple 45mm dellortos.
Driveline..
Aussie 4 speed (XU1 ratio)
Diff 3.90:1
I don't mind if it's lumpy but I still want to be able to drive it around town.
Rev wise, I'm happy to rev it a bit past 6000.. so i was thinking a solid cam.
I have the opportunity to buy a camtech. solid 248 @050, 106*LSA, lift = 501
would this be too big?
#2 piquet
piquet
  • 856 posts
Posted 20 January 2017 - 07:40 PM
have a talk to Peter Waggott at Waggott Cams in Nthn NSW. Not exactly sure where but they do good cams.
#3 piquet
piquet
  • 856 posts
Posted 20 January 2017 - 07:45 PM
For everyday driving that diff is miles too low. You'll be driving it round near the redline on the open highway with 13' rims.
I'd find a 3.36 if it was me.
Edited by piquet, 20 January 2017 - 07:45 PM.
#4 _LH1900_
_LH1900_
Posted 20 January 2017 - 08:00 PM
yea I've always been a bit worried with that.. might see how it goes
Was originally thinking a cam tech 238 @050 108 LSA and 495 lift
#5 Ice
  • 15,122 posts
Posted 20 January 2017 - 08:17 PM
Mine is 497 lift solid Crow cam and its ok to drive quite lumpy but you cant sit on 60 in 4 th gear
#6 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 21 January 2017 - 11:32 PM
Yep, that's about what I've got in my old girl too Gene & with 3.9's behind a Toyota manual box with a solid 500 lift cam, perfect for street cruising, and some daily work travel.
For something just to cruise around in, don't get too hooked up on cam specs, just make it a lumpy stick & chuck it in. The triples will certainly wake it up though.
#7 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 22 January 2017 - 04:21 AM
The camtech one is not too big but you lack adequate compression to get the most out of it. That said, it would still be ok and a lot of fun to use. Stick with the 3.9 gears tho if you do decide to use it.
If your worried about 3.9's on the highway maybe look at the second cam tech can you mentioned. You could probably run taller gears and it would be more suited to your compression I would imagine.
#8 _Bomber Watson_
Posted 22 January 2017 - 09:31 AM
Got flow sheets for the head?
#9 rodomo
  • 17,998 posts
Posted 22 January 2017 - 08:59 PM
It could have a bog stock factory cam and still take off well with that diff ratio
#10 _Denis_
_Denis_
Posted 08 February 2017 - 12:42 PM
This website may assisit in chossing a cam also.
https://www.engineba...vs Dynamic.html
#11 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 12 March 2017 - 02:21 PM
My angry 202 hated the 3.9 diff. 3.55 was heaps better, VN Borgwarner diff (with VL 3.45 gears) is better again... feels like it could go down some more but I don't want to start riding the clutch to take off. And all in an HJ with 5 speed. I reckon at least 3.36, if not the 3.08.
Edited by Dave6179, 12 March 2017 - 02:22 PM.
