LJ Excessive pedal travel
15 replies to this topic
#1 _hutch_
_hutch_
Posted 22 January 2017 - 01:24 PM
Got a strange issue going on with my car,I noticed the pedal travel getting a bit close to the floor,so yup adjust up the rear brakes right,welllllll um no ican't get the right hand brake adjuster to work correctly,at some stage it's had the adjusters removed and up until now it's never been an issue,for some reason I can't get the right hand side to adjust up,I suspect the spring to be bent so I have another to fit,I just jacked the back up and clamped off the hose to check to see if I have more pedal and it's the same,goes almost to the floor,it's not spongey and pulls up straight so I'm sort of confused,everything was replaced when I done the rebuild,been on the road a bit over 2 years,anyone got any ideas
#2 S pack
  • 15,522 posts
Posted 22 January 2017 - 01:28 PM
Sounds like a m/cyl failure. The adjusters turn opposite directions to adjust them. One side the adjuster is left hand thread, the other side has a right hand thread can't remember which side is which now though.
Edited by S pack, 22 January 2017 - 01:29 PM.
#3 _hutch_
_hutch_
Posted 22 January 2017 - 02:05 PM
Different directions to adjust the brakes ??? Never new that
#4 rodomo
  • 17,997 posts
Posted 22 January 2017 - 08:52 PM
Yeah, but they still flick the same way to adjust, bottom to top from memory.
If it lost pedal all of a sudden it's more than likely a hydraulic/master problem.
Edited by rodomo, 22 January 2017 - 08:54 PM.
#5 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 22 January 2017 - 09:07 PM
Possible wheel cylinder leaking?
Cheers DazM
#6 S pack
  • 15,522 posts
Posted 22 January 2017 - 09:40 PM
That sounds about right Rob.
#7 _hutch_
_hutch_
Posted 22 January 2017 - 10:01 PM
I wondered if it was balance thingamajig,can't think of the name of it for the life of me,it's strange it won't pump up or anything ,there is no sign of fluid leaking,it didn't fail all of a sudden,so it's got me stumped
#8 rodomo
  • 17,997 posts
Posted 22 January 2017 - 10:18 PM
Proportioning valve?
So when did you notice the problem?
#9 S pack
  • 15,522 posts
Posted 22 January 2017 - 10:28 PM
Brake fail switch & junction block if original LJ equipment. Still sounds like a failed m/cyl.
#10 _hutch_
_hutch_
Posted 23 January 2017 - 05:50 AM
I noticed it last weekend,they where still stopping the car ok,it's almost as though the master cylinder is too small is the best way I can describe it
#11 _hutch_
_hutch_
Posted 25 February 2017 - 08:54 PM
Ok,we been back from our cruise for nearly 2 weeks,I had play and adjusted up the rear brakes to the point of them dragging,has made a slight improvement,,after some more investigation I ordered a new master cylinder,was talking to an old brake specialist who asked me a heap of questions he said check the calipers,so I thought I would clamp off the front hoses and bingo full pedal,so I will pull the wheels off tomorrow and have a look,I will keep you informed
#12 KennyB
KennyB
  • 9 posts
  • Name:Kenny
  • Car:LX sedan
Posted 26 February 2017 - 08:56 AM
Sounds like the slides on the front calipers are sticking, very common in Vr-vs Commodores and gives the the pedal a lot of travel prior to the brakes working
#13 _hutch_
_hutch_
Posted 26 February 2017 - 02:50 PM
These have 2 Pistons,one is stuck,there is a bit of rust under the outer seal so frock the expense I have ordered 4 new Pistons and 2 seal kits to rebuild both spare callipers,another $240 goes on the build lol
#14 _hutch_
_hutch_
Posted 14 March 2017 - 06:13 PM
Well all fixed,brakes work good,was a bloody challenge getting the bastard Pistons out out of the calipers,I ended up welding a washer inside the Pistons and used a slide hammer to get them out,easy as....well sort of
#15 S pack
  • 15,522 posts
Posted 14 March 2017 - 08:15 PM
Good stuff Phil :spoton:. How's the shoulder holding up?
#16 _76lxJAS_
_76lxJAS_
Posted 14 March 2017 - 09:51 PM
normally  they will just blow out with compressor in the nipple.
