LJ Auto Crossmember
17 replies to this topic
#1 _DS80_
_DS80_
Posted 23 January 2017 - 01:02 PM
Fellas, whats the go with these crossmembers with the larger holes where it bolts on to chassis, they are much larger than the actual bolt itself
Attached File  16237688_10158121817775634_240539485_n.jpg   74.44K   6 downloads
Rae spares dont stock any rubber insulators for LJ's and the bloke i spoke to said hes had several people ask about them, including himself.
Only thing i could think of was to tack a large thick washer to the crossmember and bolt it up, was a little worried thre might be some slack play and it might give way
I cant be the only one who has encountered this, what have some of you blokes done?
#2 _ljshawn_
_ljshawn_
Posted 23 January 2017 - 01:28 PM
When i got my lj it just had square bits of rubber. Mine now has a different cross member bolted to the chassis now
#3 Ice
  • 15,122 posts
Posted 23 January 2017 - 01:46 PM
You should have washers before the bolts but not tacked on
#4 UCgazman
UCgazman
    UC's FTW!
  • 1,342 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 23 January 2017 - 03:17 PM
Looks identical to a LH LX UC crossmember, try these - http://www.rarespare...x?product=H1128
#5 S pack
  • 15,538 posts
Posted 23 January 2017 - 03:29 PM
This is a parts illustration for the LH/LX/UC trimatic transmission rear support which is very similar to the 1973 LJ support member and associated components.  Note the tube spacers/crush tubes (#3) that fit through the centre of the rubber insulators.
#6 Ice
  • 15,122 posts
Posted 23 January 2017 - 04:39 PM
Didnt even know you could get them
#7 _hutch_
_hutch_
Posted 23 January 2017 - 05:00 PM
The cross member that was on my LJ had a rubber damper on each other nd with a big wash r over the top
#8 S pack
  • 15,538 posts
Posted 23 January 2017 - 05:07 PM
LC. 1972 LJ Trimatic same as LC.
Edited by S pack, 23 January 2017 - 05:10 PM.
#9 _DS80_
_DS80_
Posted 23 January 2017 - 05:20 PM
Yea they look the same...when speaking with the rare spares guy, he has the same crossmember as i do, and i mentioned them rubber insulators, but his only reply was they dont make them for LJ...that lead me to believe they might not fit... i dunno...you would think someone working there would have at least tried them ha.
#10 _DS80_
_DS80_
Posted 23 January 2017 - 05:36 PM
Yep and i also noticed part no.8 reinforcment...something else im missing.
#11 S pack
  • 15,538 posts
Posted 23 January 2017 - 05:49 PM
Be the Guinea Pig, make them fit. :)
#12 _DS80_
_DS80_
Posted 23 January 2017 - 06:50 PM
Ha I guess the real part of the question is, if i used a large washer a spring washer and bolted it up would it do the job
#13 Ice
  • 15,122 posts
Posted 23 January 2017 - 06:52 PM
Yes
#14 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 23 January 2017 - 08:35 PM
would be a bit dodgy
#15 gad05
gad05
  • 420 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 23 January 2017 - 09:37 PM
I have tried the lh/lx bushes they don't fit.
#16 champagne_metallic
champagne_metallic
  • 24 posts
  • Car:UC Torana
Posted 20 May 2021 - 11:34 AM
Old topic i know, but does anyone stock these, these days?
#17 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 20 May 2021 - 01:00 PM
Just make your own.
#18 MYLJ73
MYLJ73
  • 2 posts
  • Name:TONY
  • Car:LJ
Posted 23 June 2021 - 08:09 AM
I machined 8 bushes for mine from poly which works fine. They are isolation rubbers.
