Lh Torana sway bar install
8 replies to this topic
#1 kodulh
kodulh
  • 47 posts
  • Name:Anu
  • Car:LH Torana
Posted 14 February 2017 - 05:40 PM
G day Guys,
Im middle of fitting whiteline swybar and my sway links are too close to steering rack ends. Please have a look in the photos. Abt 10mm gap..
Is it normal or am i doing something not right..
Appriciate your help
Edited by kodulh, 14 February 2017 - 05:52 PM.
#2 neglectedtorana
neglectedtorana
  • 965 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 14 February 2017 - 08:42 PM
I haven't ever fitted one so I can't compare but is there contact at any point through full lock on the steering wheel?
Would the gap be less if you clamped the mounting bracket on as in the pic it looks like it is leaning which would push the vertical link further away
#3 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 14 February 2017 - 09:03 PM
http://www.gmh-toran...tive-sway-bars/
#4 kodulh
kodulh
  • 47 posts
  • Name:Anu
  • Car:LH Torana
Posted 15 February 2017 - 05:25 AM
Thanks for the reply. I just dumy fit this. Side brackets are tight aswell as sway bar it self. Its gonna hit the links.
Gap should be more between link and the rack end.
Sent from my GT-I9506 using Tapatalk
#5 76lxhatch
  • 7,152 posts
Posted 15 February 2017 - 06:32 AM
They do sit pretty close but I've never had any issues with the boot making contact
edit: you need to install the end link bracket with the suspension at ride height to get it positioned correctly, not full droop
Edited by 76lxhatch, 15 February 2017 - 06:33 AM.
#6 kodulh
kodulh
  • 47 posts
  • Name:Anu
  • Car:LH Torana
Posted 16 February 2017 - 01:34 PM
Thanks guys. All sorted. Some reason my bumper bar is not sitting properly. Also i move side brackets left to right. Afetr they line up prity good. And now i have abt 2cm even gaps between link and the rackend.
Now it drives totalley different.
Thanks all again.
#7 _76lxJAS_
_76lxJAS_
Posted 16 February 2017 - 02:47 PM
I know nothing about these sway bar set ups but tell me how the bumper bar has anything to do with how the sway bar mounts up?
#8 76lxhatch
  • 7,152 posts
Posted 16 February 2017 - 08:43 PM
The RHS you can see in the photo above is attached to the bumper mounts via the angled plate
#9 _76lxJAS_
_76lxJAS_
Posted 16 February 2017 - 10:47 PM
ohh now i see. maybe i should of looked closer before my stupid question. my bad
