6 Cylinder Banjo Yoke Removal
5 replies to this topic
#1 _Pitty_
_Pitty_
Posted 19 February 2017 - 09:08 AM
Hi all
I am looking for the best way to remove the 6 cylinder yoke to replace with a V8 as I have tried with the rattle gun, breaker bar & CRC and the nut will not budge any tips or tricks you can share.
Pitty
#2 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 19 February 2017 - 02:47 PM
Mine wasn't that bad. Removed the centre from the housing and held it in a bench vice by the yoke and used a breaker bar.
#3 _Pitty_
_Pitty_
Posted 19 February 2017 - 04:16 PM
Thanks It might have come to a full centre out.
#4 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 19 February 2017 - 09:30 PM
Put a piece of tube over the breaker bar. I would personally renew the bearings at the same time, you will most probably change the preload setting with just the change of yoke. Your call mate, Gary.
#5 rodomo
  • 17,997 posts
Posted 19 February 2017 - 09:38 PM
Preload can be felt as you tighten up the nut if you're a clever dick?
#6 Rockoz
Rockoz
  • 3,961 posts
  • Name:Rob
Posted 20 February 2017 - 10:51 AM
Need a big rattle gun.
Could use a breaker bar long enough to touch the ground and push the car the right direction.
