Dash gauges fluctuating
#1 _project lx_
Posted 19 February 2017 - 03:57 PM
Posted 19 February 2017 - 04:37 PM
Edited by hanra, 19 February 2017 - 04:37 PM.
#3 _project lx_
Posted 19 February 2017 - 05:30 PM
Forgot to mention the volt gauge sits good
Edited by project lx, 19 February 2017 - 05:31 PM.
Posted 19 February 2017 - 06:57 PM
Source a good second hand one. Or fit a Jaycar adjustable 5v PSU.
Correct, volt gauge is not dependant on the voltage regulator.
#6 _project lx_
Posted 19 February 2017 - 07:34 PM
Posted 19 February 2017 - 07:37 PM
#8 _project lx_
Posted 19 February 2017 - 08:33 PM
Posted 19 February 2017 - 08:37 PM
ffs Hanra , don't start this yes/no thing , we got over that at express ?
The 4514 works , but it comes un-insulated which means a box is needed and extra wires and rooting around whereas the the simple 3 pin with a ground tab will bolt into place with a minimum of fuss onto the die cast body of whatever it was bolted to as per fact. , from a vague memory lapse even the "pinger" type had it's body bolted to some sort of sink , who knows what the 4514 has "built in" in terms of thermal over load and correction ?
#10 _project lx_
Posted 19 February 2017 - 08:45 PM
#12 _project lx_
Posted 19 February 2017 - 09:11 PM
Posted 20 February 2017 - 07:51 AM
The 4514 works because it has a digital switching circuit which produces little or no heat and has inbuilt overload protection, very safe. Sure there's 3 wires to connect, but that's going to be the same with any external reg. The little 3 pin regs generate a lot of heat, require a decent (larger) heat sink, are unstable in terms of voltage output and are a fire risk imo. My recommendation is don't use them. The original "pinger" regs generate only a small amount of heat, no sink, as the heat is what makes them operate.
Posted 20 February 2017 - 08:27 PM
agree , the 3 pins do get warm when pulling around 875ma , without knowing what load they are under in heavy load conditions sort of makes it hard to work out how much they draw in heavy load conditions ? , either way , one or the other , personal choice , the "pinger' was a "digital " device
some clever engineering went into making those things , both back then and now .
