Ok guys I have searched through old threads for hours and found plenty of useful info but no definitive answer, so I give up. I am finally getting my arse into gear and starting to source stuff that I need while the current 2 door (LC) is in the metal fab stage still.
I am mini tubbing to the rail by splitting the original tub. Will be running a shortened VN diff retaining the VN disc setup. Convo's or Welds or the like (not quite decided) 15 x 8.5 keeping tyre choice in the range of 235-275 wide. I have sort of decided on a 255/60 though I think as I know the 275 may be a tight fit and require extra work.
I have but two questions.
1/ In splitting the tub and widening does the back seat require any mods to fit?
2/ And this is the one I just cant find an answer for in the plethora of mini tub threads. What backspace rims will I need? Keeping in mind clearance to the shock also. I need a definitive answer so I can purchase rims and then do my mocking up and measuring so my diff guy can start chopping. I will have the diff shortened as much as half an inch shorter each side than the banjo housing if required to keep it legal.
Can anybody with a mini tubbed LC or LJ (with stretched original tubs) running 15's and big rubber shed some light?
