UC Torana caliper to stub bolts.
Posted 20 February 2017 - 07:24 PM
Thanks,
Mugginz
Posted 20 February 2017 - 07:48 PM
The UC calipers use normal bolts, not one bolt and an allen key bolt.
Posted 20 February 2017 - 07:54 PM
Posted 20 February 2017 - 10:18 PM
Depends which UC caliper you mean
And which LX caliper
LH are all same
Posted 20 February 2017 - 10:54 PM
I've picked up a pair of Girlock ones
Posted 20 February 2017 - 11:09 PM
Late UC
Just remember the hose is a metric thread... so you'll need to change them aswell
Posted 20 February 2017 - 11:14 PM
I'm gunna keep the LH booster and master cylinder and proportioning valve and I've added the UC style brake hose brackets so I'm gunna have to get new hard lines as well as caliper hoses.
I hope Maltech is still in business, his web site was down last time it checked it.
Edited by mugginz, 20 February 2017 - 11:15 PM.
Posted 21 February 2017 - 11:37 AM
Re: My last post, Maltech is still in business, his website is just down. So I should have new brake lines next week.
Posted 22 February 2017 - 04:44 PM
LH Torana - 20.5mm
UC Torana - 16.5mm
Upper bolt from LH was a little longer than the bottom one as it has to go through a mounting tab on the backing plate. The UC backing plates don't have the mounting tab that's on the LH. It mounts just by the two holes for the steering arm. Couldn't get high tensile bolts that were 4mm shorter from the bolt shop so got some high tensile washers to go with the bolts.
