gtr qtr badge plcement
4 replies to this topic
#1 willsie
willsie
  • 11 posts
  • Name:gregg
  • Car:lc
Posted 01 March 2017 - 07:53 AM
need help on the measurements plz  i have found to
measurements in the forums
ones 216 from the door jam qtr edge
the other is hole measurments which puts the badge at 234 from qtr edge
or did they just slap them anywhere ?
#2 _oz772_
_oz772_
Posted 01 March 2017 - 10:03 AM
Pretty sure you will find the 216mm as in the picture is correct. They certainly didn't just slap them anywhere, though I remember seeing standard LC's that had had the badges attached by owners, and they were slapped any old where. Stick with this, and you can't go wrong IMO. By the way, the holes will be in the same place either side, though the top and bottom of the badge won't necessarily be due to the slope of the badge. I'd use the right side as a template for the badge position. Then measure the hole position once you have the 216mm sorted, and use that hole position as the template on the left side. Hope that makes sense.
11%20lc%20gtr%20quarter%20panel%20badge.
#3 RallyRed
  • 7,804 posts
Posted 01 March 2017 - 12:55 PM
Wonder if there was a slight difference plant to plant?....assuming they were drilled off a jig, but the jigs were made locally"?
#4 willsie
willsie
  • 11 posts
  • Name:gregg
  • Car:lc
Posted 01 March 2017 - 01:41 PM
There's not much in the difference but the longer measurement says his is genuine gtr and did find another one since which is about the same as it could pick either one badge position wont make it go faster
#5 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 04 March 2017 - 06:44 AM
There is a pinned post somewhere for this. There was much debate on what was correct
http://www.gmh-toran...e-2#entry834060
