Lx front end rebuild.
#1 _fli304_
Posted 08 March 2017 - 07:55 AM
Posted 08 March 2017 - 08:39 AM
The big advantage of using UC top control arms is the ability to add more positive caster to the wheel alignment. With greater positive caster the car will have a more weighted feel but better vehicle stability and better camber change through corners. Its shopping trolley verses go cart steering geometry theory.
You can also expect better static cambers not having to over stack the inner top control arm mount with heaps of shims to get a decent wheel alignment. If your using UC top control arms is also best to use the UC steering arms, they offer better bump steer curves especially when using the UC arms.
#3 _fli304_
Posted 08 March 2017 - 10:12 AM
You can also expect better static cambers not having to over stack the inner top control arm mount with heaps of shims to get a decent wheel alignment. If your using UC top control arms is also best to use the UC steering arms, they offer better bump steer curves especially when using the UC arms. Cheers
Thanks for the info. All makes sense now. Better start the hunt for these. Thanks again.
