Gidday all, after some advice on the best way to repair the cracking as shown in the photo. It's the point where the K Frame (I think it's called out rigger) bolts to the chassis Chassis rail.doc 1.9MB 94 downloadss rail. 75 LH if your wondering.
Outrigger to chassis rail repair
_Steveg_
, Mar 12 2017 10:38 AM
4 replies to this topic
#1 _Steveg_
Posted 12 March 2017 - 10:38 AM
Posted 12 March 2017 - 12:34 PM
Looks like its corroded from the inside out. Needs cutting out and replacing with a fabricated section.
Posted 21 March 2017 - 05:08 PM
High mileage v8s tend to get a crack but it's notmally on the left of the washer in your pic. That looks like there might be something else going on like rust . Cut a section of floor pan out from inside so you can get in there and have a good look and repair
#4 _Steveg_
Posted 27 March 2017 - 06:36 PM
Thanks for the replys, currently in the process of removing rust from the floor pans. Will do as you sugested a have a look. Cheers.
Posted 27 March 2017 - 07:54 PM
That isn't cracking that is rusting through.
