LC glovebox insert - how the hell
Posted 18 March 2017 - 05:40 PM
How the hell do you install an LC glovebox insert.
Cheers Brian
Posted 18 March 2017 - 06:15 PM
Posted 18 March 2017 - 06:18 PM
Take your time, this way, that way, a bit of pushing is required.
Most importantly remain calm.
#4 _hutch_
Posted 18 March 2017 - 06:45 PM
I got mine in after a big fight,then it just sort of fell in,through the front opening,I always wondered if the trick is to fit it before before the heater bits
I got mine in after a big fight,then it just sort of fell in,through the front opening,I always wondered if the trick is to fit it before the heater bits
Edited by hutch, 18 March 2017 - 06:47 PM.
Posted 18 March 2017 - 07:59 PM
(Failed to remain calm removing old one)
Have my heater parts out, but from memory I could get it to work from behind.
Happy to give it a go if someone is interested
Edited by Lc69, 18 March 2017 - 08:00 PM.
Posted 19 March 2017 - 11:48 AM
Posted 19 March 2017 - 03:32 PM
Ok, looks like way more calmness is required.
I needed medical intervention after I removed it, so Im hoping the insert and I see eye to eye after the install phase.
Thanks for the advice.
Posted 19 March 2017 - 03:50 PM
Posted 19 March 2017 - 06:25 PM
Hi
Mr GMH was a comedian. The workshop manual instructions include (after removing screws etc.) "carefully ease compartment out through instrument panel aperture". Installation - "reverse removal opeations".
That doesn't sound difficult at all
Bazza
Posted 19 March 2017 - 08:13 PM
Take some pictures or let us know how it goes.
Mine is looking at me on the work bench.
#11 _Bomber Watson_
Posted 19 March 2017 - 08:43 PM
My glove box is now my fuse box with a nice metal lid to hide it all for this exact reason.
#12 _SableMet7/73_
Posted 22 March 2017 - 06:32 PM
Edited by SableMet7/73, 22 March 2017 - 06:33 PM.
#13 _SableMet7/73_
Posted 22 March 2017 - 06:37 PM
Posted 22 March 2017 - 08:08 PM
Hi Jono
The sides go in behind the flange on the dash panel opening. Yep, I also had to trim some out of the opening in the end of the box to allow the door stay bracket thing to fit & the rivet holes to line up properly.
Dave.
#15 _SableMet7/73_
Posted 24 March 2017 - 10:23 PM
Thanx Dave, fits like a glove.......box.
Thats another little pre-assembly job off my list & tucked away, tho I'm a long way off finishing.
Next!.. As I've been messing around with cardboard I might as well finish that drop-in cardboard mask for the black spray job
for my grille, then the steering column build.
J
ha! giggle (meant jiggle)
Posted 12 August 2017 - 08:24 PM
I've taken photos to help anyone else that finds themselves doing this.
Trimming the joins would likely make it easier, but I didn't worry about it.
Installing from the front, push the drivers side end into the opening
Slide towards the drivers side inside the cavity
Carefully, with some pressure, push the top of the insert , past the sheet metal lip.
Slide the insert back to centre, push the passages side of the insert past the sheet metal, and locate everything relative to the mounting holes.
Assemble.....
IMG_9930.PNG 1.75MB 20 downloads
Edited by Lc69, 12 August 2017 - 08:29 PM.
Posted 12 August 2017 - 08:33 PM
IMG_9932.PNG 1.45MB 13 downloads
IMG_9933.PNG 1.42MB 17 downloads
Edited by Lc69, 12 August 2017 - 08:38 PM.
