LC brake booster trouble
Posted 28 March 2017 - 05:00 PM
I bought my car with brake problems. The brakes only grab right near the floor. I put a kit through the pistons, got new rear slaves and a new m/c. Now I looked at the booster and it seems the pushrod is too short by an inch. I think the mc and booster are from a HG or simikiar. Mc part number is p7210. Does anyone have a part number for the booster I need as mines not on it. Has anyway had this problem or have I done something wrong? The booster has rusty fluid in it so has to go anyway. Also need one asap so I can move my car.
Thanks all.
#2 _hutch_
Posted 28 March 2017 - 05:56 PM
Posted 28 March 2017 - 06:13 PM
LC and LJ have different length rods from booster to master cylinder, you could have wrong one
also there is a rubber pad inside the booster if this is missing it will cause brake grabbing
Posted 28 March 2017 - 06:33 PM
It seems I need the rob to protrude an inch but it's only out a few mill
Edited by D-Train, 28 March 2017 - 06:35 PM.
Posted 28 March 2017 - 07:13 PM
Sounds like you have an LJ/HQ type master cyl on an LC booster.
Either purchase a HK,T,G & LC master cyl to suit your booster or have the booster recoed and fitted with the longer LJ pushrod.
Posted 30 March 2017 - 06:49 PM
the rods can be changed they just slide out of booster, need to get the right 1 for the master cylinder.
but you need to check the rubber pad inside doesn't move when you do it.
as S pack said seems like you have LJ master with LC rod.
