What dose this plug do
Posted 01 April 2017 - 02:19 PM
Posted 01 April 2017 - 03:31 PM
Goes to the fuel sender mate.
#3 _76lxJAS_
Posted 01 April 2017 - 04:51 PM
Posted 01 April 2017 - 04:55 PM
^^^What they both said^^^
Posted 01 April 2017 - 06:46 PM
kick down solenoid wire , goes through the hole in the tunnel onto the side of the gearbox
fuel sender.is a different colour ?
Posted 01 April 2017 - 07:05 PM
Are you sure? looks like the female pin connector for the fuel sender. Does the kickdown solenoid use the same type of connector? I've not had much to do with slushmatic transmissions.
Posted 01 April 2017 - 07:09 PM
Looks like the pic was taken inside the cab (drivers side?) , not the boot ? , yes both traumatic kickdown and fuel sender have a similar fitting ?
Posted 01 April 2017 - 07:26 PM
My manual (Gregorys) shows the kickdown as orange and the fuel sender as light brown.
will check my car...... dam my LH was manual
Edited by UCSLE, 01 April 2017 - 07:30 PM.
Posted 01 April 2017 - 07:31 PM
yep they use the same type plug
#11 _76lxJAS_
Posted 01 April 2017 - 08:06 PM
Posted 01 April 2017 - 08:09 PM
We have the winnerkick down solenoid wire , goes through the hole in the tunnel onto the side of the gearbox
