Hatchback Tail Light Wiring
14 replies to this topic
#1 Terry Marsh
Terry Marsh
  • 43 posts
  • Name:Terry Marsh
  • Car:LH SLR / LX SS Hatch
Posted 03 April 2017 - 10:54 AM
I was wondering if someone could post some photos of where the Tail Light Wiring Harness sits in a Hatchback. Does it go through or over the Rib behind the Back Seat / where does the Wire pass though the Rear Light Panel into the Lights themselves?
#2 hanra
  • 10,814 posts
Posted 03 April 2017 - 11:07 AM
Does this give you any clues Terry? Hopefully a hatchback owner can post up some pictures.
#3 Terry Marsh
Terry Marsh
  • 43 posts
  • Name:Terry Marsh
Posted 03 April 2017 - 11:53 AM
Brad, I have that Diagram - enlarged it - still can't make out where exactly it runs. Where Wiring comes up to Lights, where you think the Wire will go, the Light Fittings/Bulbs won't fit through the Hole! Same as the Rib behind the Rear Seat.
#4 hanra
  • 10,814 posts
Posted 03 April 2017 - 12:14 PM
Is it different to an LH?
#5 Terry Marsh
Terry Marsh
  • 43 posts
  • Name:Terry Marsh
Posted 03 April 2017 - 03:54 PM
Both Panels are different on a Hatch.
#6 hanra
  • 10,814 posts
Posted 03 April 2017 - 04:34 PM
Ok, well guess we just wait for a kind hatch back owner to post some pics. Pics tell a thousand words.
#7 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 03 April 2017 - 07:47 PM
Don't have a pic handy Brad but the loom follows the wheel arch around then goes through gaps next to the wheel arch under that boxed floor section.
If you are still not sure then hit me up for a pic and I will pull out the mats.
Edited by mika03au, 03 April 2017 - 07:48 PM.
#8 hanra
  • 10,814 posts
Posted 03 April 2017 - 08:40 PM
I think pics will reveal everything that Terry needs to know.
#9 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 04 April 2017 - 08:55 AM
Have a little more info which may help. See pics.
Actually big thanks as you can see my sub floor needs a clean up and treating of some surface rust which I wasn't aware of.
Attached File  post-14134-0-77113200-1491181631.png   147.84K   15 downloads
Attached File  IMG_0819.JPG   166.4K   10 downloads
(rear tail lights loom off outboard under floor then feed in above floor to lights)
Attached File  IMG_0815.JPG   129.45K   16 downloads
(not sure where or if you would be able to get those clips - rare spares perhaps)
#10 hanra
  • 10,814 posts
Posted 04 April 2017 - 09:10 AM
Wow that is totally different to LH! Thanks a lot for those pics Michael.
#11 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 04 April 2017 - 09:17 AM
My loom runs, I think, in the wrong place, it should run directly up in to the boxed sub floor under the rib section (if possible as I can't see there on my car with out further disassembly).
The loom here is original and it is sitting how the natural form of the loom was.
Attached File  IMG_0816.JPG   72.5K   11 downloads
Edited by mika03au, 04 April 2017 - 09:18 AM.
#12 hanra
  • 10,814 posts
Posted 04 April 2017 - 09:24 AM
Is that the fuel tank sender wire I see disappearing into the floor there?
#13 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 04 April 2017 - 02:11 PM
Yup that's where the fuel sender wire goes.
Agree with the above comment that the harness goes straight up the diff tunnel and under the timber sub floor, there's a circular hole to allow the harness to go through the sheet metal that the timber sub floor screws to.
#14 hanra
  • 10,814 posts
Posted 05 April 2017 - 10:55 AM
Hopefully that's the info that Terry needs.
#15 Terry Marsh
Terry Marsh
  • 43 posts
  • Name:Terry Marsh
Posted 05 April 2017 - 01:06 PM
Thanks every one for your replies - I think that info will get me sorted - I'll look at it & the Hatch over the weekend and report back.
