Thanks to the owner for the photos.
Posted 05 April 2017 - 04:03 PM
Posted 05 April 2017 - 06:19 PM
sorry if I'm stupid, but what's the go?......
Posted 05 April 2017 - 06:29 PM
Posted 05 April 2017 - 06:55 PM
Red goes faster
Posted 05 April 2017 - 06:57 PM
Posted 05 April 2017 - 07:39 PM
23F1 and 19G1 these are the only two cast batches that I found for the Ck I haven't had enough Nk blocks to give a cast update
XU-1 RAT. 19G1 was also the cast of CK 54845.
Cheers gong
Posted 05 April 2017 - 08:39 PM
John,As far as i'm concerned, The pictures i have put up are from a CK Adelaide car which was wrecked out years a go it still has a xh cam steel crank and the cast dates for NG blocks are 7G2 and 10G2 which are in the warranty period. I have only seen 2 NK blocks yours and one in nz ex race car.
A few owners of 3100x xu1,s and CK have NG block in their cars.
Posted 06 April 2017 - 06:53 AM
To easy man I understood what you was saying .
Cheers gong
Posted 06 April 2017 - 09:37 AM
Arthur Tucker RIP was NASCO Material Control Supervisor for LC,LJ Torana inward, outward and stock lost division.
There was a supervisor for each department eg: Chev,Pontiac,Buick and HK,HT and HG.
Posted 20 June 2017 - 09:19 PM
A F231 NG block apparently a CK cast date not sure if that is correct.
Posted 21 June 2017 - 07:34 AM
Anthony, I would say this is a restamp as with the CK the 23 comes first the the F-1.
I'm no engine block research scientist but wasn't letter first a 60s thing
Cheers john Kemp (gong)
Posted 21 June 2017 - 10:19 AM
Hi
From my limited interest and research I believe that the change to engine block cast dates from the old (USA) date format of Month/Day/Year to British format Day/Month/Year occurred in July 1971.
We know that the engine numbers were not always stamped in strict order of production of the actual block, so it follows that there could be engines fitted to cars of all models during the June/July transition period that have the 'earlier' Month/Day Year format cast date such as June 23rd 1971 (F 23 1). The engines that should raise suspicion are the 3100x that have the later Day/Month/Year cast format.
As a side note - it is interesting that the cast date format never changed when it came to the head casting until 1973.
Bazza
Posted 21 June 2017 - 10:33 AM
John,Not sure what you're saying john but in your thread LC XU1 BLOCKS you state that F231 month.day,year is a CK cast date.Here is a restamp of a F231 the block is in the Pest Control XU1 ex race car
John,Just doing research.
Posted 21 June 2017 - 01:16 PM
That is good info to have from you both,,, maybe I have turned down original blocks in the pass,,, now were is my little black book.
Cheers john
Posted 21 June 2017 - 06:03 PM
Posted 26 July 2017 - 03:35 AM
Not one picture of a NK block has ever been produced. I dont believe they exist, unless restamped.
No such thing as a nk block.you won't see a picture as they don't exist.
Jason
Posted 26 July 2017 - 08:38 AM
Yes there are NK blocks I have owned and seen them in the passed,,, there is a one owner old man that lives in the Adelaide hills that owns a white CK car that had a replacement NK put in it under warranty back in 74, I went and looked at the car the same time I was down there with departed forum member daz
I got know pics at the time but he did. There was a post on the forum somewhere with all Holden motors and the replacement ones as well and the NK was in there too.
Cheers gong
Posted 26 July 2017 - 11:56 AM
Posted 26 July 2017 - 06:41 PM
Posted 27 July 2017 - 04:50 PM
Posted 27 July 2017 - 06:17 PM
Correct still no photos of nk 186 block in past topics on 186 blocks. Unique cars and parts Holden engine guide needs to be amended
Posted 27 July 2017 - 07:59 PM
Plenty in here: https://www.google.c...iw=1280&bih=884
Posted 30 July 2017 - 11:52 PM
Posted 31 July 2017 - 12:00 AM
I've got a NG block sitting around that I don't want if anyone's keen.
Will have to check the other numbers though.
Perfect for anyone who doesn't have the original 186 engine for their HR, HK, HT, HG, or LC XU1 resto.
