I've been struggling to remove a fan clutch for a 202 on a WB. When you try to undo the nuts holding fan clutch to pulley, the pulley rotates also. Applying tension to fan belt not enough to keep pulley in place.
I've attempted to counter pulley rotation by inserting a screwdriver slipped between bolts but cant apply enough torque and cheap spanner has too much slop and starting to round off nut. Spanner will be upgraded. I'm considering purchasing a Schley Universal pulley holder to make job easier.
11250 OFFSET PULLEY HOLDER – SCHLEY PRODUCTS INC.
Does anyone have experience with removing fan clutch from 202? I can't see a nut on the fan clutch itself, it appears that just removing pulley nuts will decouple it from pulley. How would you approach this?
