torque setting spark plugs
28 replies to this topic
#1 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 20 April 2017 - 12:15 AM
this might be a stupid question does anyone know the torque setting on holden 6 spark plugs.if you over tight them it can cause detonation and other problems.
#2 hanra
  • 10,832 posts
Posted 20 April 2017 - 06:14 AM
Care to explain?
#3 Dr Terry
Dr Terry
  • 3,276 posts
Posted 20 April 2017 - 07:04 AM
There are 2 types of spark plugs used in Holden 6-cyl engines. Pre-HQ (& XU1) engines use a plug with a metal sealing washer while HQ onwards use a taper seat plug.
Neither type requires a great deal of torque, however the washer seat type requires more torque on initial fitting to get the required crush for the washer. From memory the torque required is about 30-35 Nm, although I'd have say after 45 years + in the motor trade I've never seen a mechanic use a torque wrench to fit a spark plug. It's more a matter of 'feel'.
The taper seat type requires very little torque to fit (around 10 Nm). Not much more than just a 'nip'.
The most common error made is people over-tightening taper seat plugs thinking that they have washers. Once they've been in the engine for 20,000-30,000 km they are very difficult to remove, they often snap off.
Dr Terry
#4 _Bomber Watson_
Posted 20 April 2017 - 07:45 AM
Im interested in the science behind how it can cause detonation.
#5 _Lazarus_
_Lazarus_
Posted 20 April 2017 - 12:04 PM
It 'strangles' the spark plug if I remember correctly, kind of like a duck shitting all down your trousers while you're strangling it.
#6 arrimar
arrimar
  • 3,121 posts
Posted 20 April 2017 - 12:27 PM
A duck..really? Cats yes but never had a duck do that.
#7 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 20 April 2017 - 01:10 PM
Why not go to your plug brands website and check?
#8 arrimar
arrimar
  • 3,121 posts
Posted 20 April 2017 - 01:46 PM
NGK data.
BP6ES (washer seat) 25-35Nm in cast iron 15-30Nm in alloy
BP6FS (taper seat) 15 - 25Nm in cast iron 10-20Nm in alloy
(1 Nm = 0.7375 lb ft)
#9 _LS1 Taxi_
_LS1 Taxi_
Posted 20 April 2017 - 02:01 PM
I wish I never clicked on this thread.
#10 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 20 April 2017 - 03:18 PM
just going on the ngk web site about over tighten spark plugs can cause detonation.
#11 _Bomber Watson_
Posted 20 April 2017 - 03:25 PM
Just looked it up, not really much of a scientific paper there providing us with is it?
Looks to me more like a catch all "you cant sue us" type comment.
1/2" ratchet, give her a nip, go have a beer.
#12 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 20 April 2017 - 03:40 PM
i just had another look it says if its under tighten not fully seated heat transfer will be slow and cause pre ignition and detonation,so i got it wrong about the over tighten causes detonation.my apologies.
#13 _Bomber Watson_
Posted 20 April 2017 - 04:08 PM
No it does say under over tightening that the same things can occur.
#14 S pack
  • 15,538 posts
Posted 20 April 2017 - 05:25 PM
If you hadn't made a post no one would have known. :stirpot:
#15 RallyRed
  • 7,841 posts
Posted 20 April 2017 - 06:03 PM
going out on a very shakey branch here....and I'm pretty sure it would be bees dick stuff....but if Arnie cranked the plug in a few more turns...wouldnt it take up more cc's in the chamber...and increase the compression...and risk detonation.?
Cant imagine it ever occurring in practice though?
#16 S pack
  • 15,538 posts
Posted 20 April 2017 - 07:00 PM
Col, he'd snap the plug well before a few more turns. :)
#17 RallyRed
  • 7,841 posts
Posted 20 April 2017 - 08:21 PM
yeah, thought so.....but
#18 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 02 May 2017 - 08:16 PM
Has anyone checked with the RSPCA to see if they have heard about the phantom duck strangler on this forum? Should be easy to spot , got duck shit all down the front of his strides.
#19 ozyozyozy
ozyozyozy
  • 944 posts
Posted 02 May 2017 - 10:26 PM
Over tightening can cause issues too.
We actually had a technical bullietin at a dealership i worked, for this reason.
its not a normal thing for a factory to come out and say in this way.
This was for a small diameter spark plug tho, caused them to stretch.
#20 _big jack_
_big jack_
Posted 05 May 2017 - 05:13 PM
They also say the electrode should face a certain way in the combustion chamber for what ever reason, any one shed some light or spark lol on this?
#21 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 05 May 2017 - 07:39 PM
Crikey :) , when did nipping up a plug become so technical ?
Have heard that you can "index" the plug to face one way or the other but how much difference it makes to anything might not make
all that much difference  at all ? , not sure , it could be a fable but vague memory recalls that they tend to have the sparky bit facing
the exhaust valve ,(i.e. the ground electrode facing away from the exhaust valve) .
Would take a bit of time to mark all plugs and then work out how much material needs to be removed off the taper or face in the case
of squashed seal ring type to get them all pretty close , then make a jig to modify the ones that need trimming , it might not make much difference at all but then again next time a set of plugs is pulled it might be worth a look at which ones face where and are the "cleanest" looking ?.....either that or buy a million plugs and find out which ones fit up pretty close .
#22 hanra
  • 10,832 posts
Posted 05 May 2017 - 08:24 PM
I bought 16 plugs from super cheap auto and run each one through until I found 8 that indexed correctly without having to use shims. I just marked the insulator inline with the electrode on each one so I knew the position.
Edited by hanra, 05 May 2017 - 08:29 PM.
#23 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 05 May 2017 - 08:26 PM
Indexing works- albeit small gains...
And you can buy washer kits to help index. My 6 took 9 plugs to index last time I did it, and that was without any special washer kit. With a washer kit 6 plugs would do it in a 6. 8 in an 8 and so forth.
However, you will get more gains from side gapped plugs. I gained just under 1mph on drag strip with side gapped and indexed plugs over standard. To me thats about 5hp. Worth the 10 minutes of frigging around when you could pay 1k in porting to gain 10hp.
Edited by LC-GTR-1969, 05 May 2017 - 08:28 PM.
#24 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 05 May 2017 - 10:03 PM
for heat silver plugs are the best then copper plugs
#25 ozyozyozy
ozyozyozy
  • 944 posts
Posted 05 May 2017 - 10:09 PM
Be more gain at a drag strip in setting the car up to launch harder, reducing 60ft time, that can be as simple as getting the tyre pressure correct.
