torque setting spark plugs
28 replies to this topic
#26 LXCHEV
LXCHEV
  • 2,783 posts
  • Car:'76 LX - 383 Chev
Posted 05 May 2017 - 10:14 PM
Do both! Get the car launching with indexed plugs.
Can I ask what 'side gapped' plugs means?
#27 EunUCh
EunUCh
  • 2,696 posts
  • Car:japos
Posted 06 May 2017 - 05:03 PM
Side gaping i think would mean careful manipulation of the ground electrode so that the spark gap is now on the side of
the center electrode rather than on the end of center electrode ? ,similar to what they did close to a hundred years ago with some
plugs , surface discharge would probably be ok as well but not sure if they are available to suit some of these engines, and i think they need a very good spark generator to operate properly.They basically have the ground electrode all the way around the  center
electrode , which is slightly "buried" in porcelain below the level of the grounding bit.
#28 Bomber Watson
Bomber Watson
    Not nearly as smart as Lazarus
  • 20,471 posts
  • Name:DJ
  • Location:Rockhampton, the exact center of my own TINY universe. Also the home of the worlds longest location.
  • Car:Mixed fleet of Taxi's and hair dresser mobiles.
Posted 07 May 2017 - 11:13 AM
Yeah correct, you cut off the top of the earth strap then hit it over so its the right gap from the electrode.
Seems to make them run a touch hotter and not foul up as quick.
#29 lawn bowls
lawn bowls
  • 62 posts
  • Car:72 lj 4 door
Posted 07 May 2017 - 08:48 PM
the spark plugs with 2 or more electrodes dont need gaping and suppose to be less chances of fouling the plug also.
