Pushrod lenght for F300 cam
Anyone used one
7 replies to this topic
#1 Redslur
Redslur
    Has been Torana owner
  • 3,532 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 22 April 2017 - 09:46 AM
Hi kids.  Looking to put a Crane F300 solid in my big 355 engine with VN heads. Now my dilemna is that I will be purchasing the cam as a kit which inlcudes the pushrods.  Now without being able to install the cam to measure the pushrod lenght required, it is a bit hard to gauge the length I need.  I know there are many variables that influence the length like deck height etc etc, but has anyone used one in a similar combo that I could use as a reference?  I used 8.7's with my F280.
Any help would be appreicated.  Not going to hold anyone to it, just using it as a reference that may help.
Cheers, Gerry
#2 76lxhatch
  • 7,153 posts
Posted 22 April 2017 - 10:39 AM
Unless the cam has a different base circle diameter or you're using different height lifters the pushrod length would be the same?
#3 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 22 April 2017 - 05:56 PM
what about the crane cc300a cam gerry excellent cam about 610-620 thou lift/strong take off mid range and top end speed for the drags
#4 Redslur
Redslur
  • 3,532 posts
  • Name:Gerry
Posted 22 April 2017 - 09:34 PM
Same cam bud but to suit VN heads,
#5 ozyozyozy
ozyozyozy
  • 944 posts
Posted 23 April 2017 - 12:02 AM
Cut an old pushrod, thread the guts, cut down a bolt, you now have an adjustable pushrod to guage length,.
I would absolutely check length and rocker geometry if installing a new different cam.
#6 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 23 April 2017 - 12:18 AM
ask crane cams web site.
#7 gtrboyy
gtrboyy
  • 3,137 posts
Posted 23 April 2017 - 02:45 AM
I'd assume current pushrods be near enough if you have not changed head gaskets or machine work.
How does camtech compare?
As noticed few av8 guys like those in custom grind over crane these days + closer to home.
#8 Redslur
Redslur
  • 3,532 posts
  • Name:Gerry
Posted 23 April 2017 - 09:21 AM
I certainly will be checking the geometry Ozy hence me asking. Just trying to save myself having to buy two sets of pushrods. Only costs $40 for a pushrod measurer so will buy one of those this week.
Might check the Crane website as suggested.
I will stick with the Crane cam choice as I have used several of their cams and I really like them., This thing is going to run mid 10's if all goes well :-)
