Nine inch diff pinion seal leak
3 replies to this topic
#1 rexy
rexy
  • 3,576 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 22 April 2017 - 09:32 PM
One of the cars has a small leak from the pinion seal. The centre is of uncertain history but otherwise behaving fine.
Is there any way to tell which seal it has before pulling it apart to fix?
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 22 April 2017 - 11:00 PM
Hi Rexy, Od & id measurements possibly, presume that your talking 9" ? Gary
#3 arrimar
arrimar
  • 3,113 posts
Posted 23 April 2017 - 09:04 AM
Look up a nine inch diff id chart for which seals fit which, alternatively you can pull the whole pinion assembly out while leaving the rest of the centre in the car. Diff shop can then change the seals and reset the preload without you having to take off a wheel.
#4 Bernie
Bernie
  • 301 posts
  • Car:2 lx Hatches and 3 lx 4 doors
Posted 23 April 2017 - 09:50 AM
Common for the yoke to come loose and the seal will then weep .If that is the case you will most likely have a collapsable spacer in it for setting preload .Spend the $and put a machined spacer and use loctite on the yoke to get it to stop floating around .Older shafts and yokes do have an issue once they get some wear in them
