Chassis axle stand points
2 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 24 April 2017 - 07:17 PM
Hi all ,I would like to know suggested axle stand points for LC-LJ ,can't be under the diff housing as I'll need to lower this at some point ,I will be using four .Trying to avoid damage to the underside or the car ,are the chassis rails ok for this?Thanks Paul.
Edited by Indy Orange, 24 April 2017 - 07:22 PM.
#2 jpxu1
jpxu1
  • 546 posts
Posted 24 April 2017 - 08:49 PM
If I needed movement of the rear axle, then I always used to place the axle stands under the chassis rail in the inverted V created where the front trailing arm mount joins the rail. (Fortunate to have the luxury of a hoist these days). Don't forget the bit of carpet if you have good paint to protect :-)
Cheers,
JPXU1
#3 _Bomber Watson_
Posted 25 April 2017 - 02:36 PM
As above, I generally shove them directly infront of the LCA moutning point, in the nice v, and just behind of the front x memeber rear mounting bolt thingo's when im doing that kinda work.
