Axles in LC GTR
25 replies to this topic
#1 _Muzzy_
_Muzzy_
Posted 07 May 2017 - 03:03 PM
Hi can anyone tell me are the axles from the factory are the axles fine or course spline in a LC GTR from the factory?
#2 RallyRed
  • 7,840 posts
Posted 07 May 2017 - 03:33 PM
10 spline to my knowledge,  = course
#3 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 31 May 2017 - 06:26 PM
I don't know why people are still using them. Why not just buy the billit lsd 4 pin carrier for 600 and fit 28 spline axles. If you want to keep ur torana pattern just re drill to suit. Any diff shop should be able to do it for u.
#4 Ozchuck
Ozchuck
  • 45 posts
  • Name:Chuck
  • Car:Not enough !!
Posted 11 June 2017 - 02:14 PM
I'm after some fine spline axles for my LJ. Anyone know where the best place to source these are? Is there anyone (Sydney?) doing just the axles to fit into regular banjo fine spline LSD's?  I have 2 x 3.36 fine LSD centres and I may as well use them.
#5 RallyRed
  • 7,840 posts
Posted 11 June 2017 - 05:48 PM
I think Keith Croft is still making them. He uses billet axles and machines the splines to suit. Western Sydney. Knows his stuff.
#6 _adz372_
_adz372_
Posted 11 June 2017 - 08:07 PM
Where abouts do you buy this $600 lsd billet carrier? Is it for the banjo? Thanks
#7 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 11 June 2017 - 08:54 PM
http://stores.ebay.c...14.l1581&_pgn=3
This bloke use to do them.
#8 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 11 June 2017 - 08:58 PM
Has also been talked about in different thread. Its a different way though.
http://www.gmh-toran...anjo-diff-ljlc/
#9 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 11 June 2017 - 09:04 PM
Just did a quick search and could only find the harrop 1 for the banjo. But it's over 1200.
https://www.harrop.c...banjo-28-spline
#10 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 11 June 2017 - 09:20 PM
You can also chech with summit racing to see if they have anything. I know they deal with eaton true trac stuff aswell
#11 Ozchuck
Ozchuck
  • 45 posts
  • Name:Chuck
  • Car:Not enough !!
Posted 12 June 2017 - 02:42 PM
Thanks Col,
Would you have the contact details for Keith Croft as I can only locate a Croft Fabrications at Oakville but it says it's permanently closed.
Would you know roughly what billet axles are going to match the banjo centre?
#12 _adz372_
_adz372_
Posted 12 June 2017 - 05:15 PM
Ok thanks for the tips ShtStr
#13 RallyRed
  • 7,840 posts
Posted 12 June 2017 - 06:23 PM
I'll PM you his number Chuck
#14 Dodgey
Dodgey
  • 437 posts
  • Name:Steve
Posted 12 June 2017 - 06:58 PM
If you want to use a factory 23 fine spline LSD then Gemini axles are a cheap option. They need to be machined (shortened) and re-studded to suit Torana wheels. The Harrop Tru Trac is available in 23 spline but will be more expensive than a Holden LSD.
#15 Ozchuck
Ozchuck
  • 45 posts
  • Name:Chuck
  • Car:Not enough !!
Posted 13 June 2017 - 10:11 AM
Thanks Steve.
I'd suspect Gemini axles would be pretty short in supply these days. I'd love the Harrop Tru Trac but I already have 2 Holden LSD's so I might as well use them rather than fork out more dosh.
#16 warrenm
warrenm
  • 2,106 posts
  • Car:1972 LJ Torana
Posted 14 June 2017 - 07:31 AM
The Diesel Gemini & Station wagon are the better axle Gemini axles.
#17 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 14 June 2017 - 10:08 AM
Thanks Steve.
Sell them to some fanatics who go on about original car and buy the harrop one and drive past and wave when they brake the holden one.
#18 S pack
  • 15,538 posts
Posted 14 June 2017 - 12:04 PM
Thanks Col,
I may be wrong but I believe Keith is in poor health and has closed his business.
#19 RallyRed
  • 7,840 posts
Posted 14 June 2017 - 01:10 PM
yeah, unfortunately, I believe you are correct Dave.
#20 Heath
  • 18,309 posts
Posted 14 June 2017 - 11:45 PM
The ones for Aussie cars (Banjos and Borg Warner 78's) are done by Eaton specifically for Harrop. You won't find them listed on Summit.
They have a premium price tag, too. The volumes would be a lot lower on those products than TrueTracs for American cars such as 10-Bolts and 9"s.
#21 Ozchuck
Ozchuck
  • 45 posts
  • Name:Chuck
  • Car:Not enough !!
Posted 17 June 2017 - 12:41 AM
Shame about Keith. Hope he gets better. Sounded like a really nice guy on the phone.
I think I may go down the path of selling the LSD's and going Harrop as Shtstr suggested. The Eatons are $1200 from Harrop for 28 spline. Billet axles are about $1500 to suit from Bosnjaks in Sydney + Bearings.
Damn....Anyone want to buy 2 x 3.36 LSD's for, oh I don't know - $2700 sounds like a good price.............  :D  :D  :cry:  :cry:
#22 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 17 June 2017 - 11:33 AM
Mate i just got a 078 borgwarner diff and had it shortened for less than 2g all up. Your lsd diffs are worth 600 to 750 each at the moment.
If you go to the wreckers and get 2 vn vp vr vs axles they are 1 piece and are fully heat treated so you can re spline them and re drill to torana pattern and get the locating hub turned down for torana aswell. All up they shouldn't cost more than 600 including buying the axles. You will also need to put the torana bearing on the axles
Edited by Shtstr, 17 June 2017 - 11:35 AM.
#23 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 17 June 2017 - 04:34 PM
Harrop recut my banjo Detroit Locker side gears to take ( I think) 23 splines. Keith Croft reworked some Commodore axles for this with screw on bearing retainers for good measure and since then no broken axles , where previously about 2 hillclimb meetings was the service life of a coarse spline axle.Car has about 250HP and as you know Detroit Lockers don't take prisoners especially when you run sticky race rubber.
#24 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 17 June 2017 - 09:06 PM
I run re splined vr axles in my ten bolt Salisbury be hind a 500hp turbo 6. Been in the car for 6 years now and haven't had any problems at all.
#25 caterham2
caterham2
  • 348 posts
Posted 17 June 2017 - 11:02 PM
Chuck, Harrop did the rework of the side gears for about $200.00, Keith Croft supplied the reworked axles for about $850.00 delivered to country Victoria. All this was about 8 years ago, axles still in car, no issues. Someone else apart from keith will be able to do them, ask someone running Group NC for a suggestion as to who.
