Starter motor turned over one day then not the next
#1 _TheGatch_
Posted 08 May 2017 - 08:08 AM
Posted 08 May 2017 - 08:09 AM
Posted 08 May 2017 - 11:43 AM
AS above (try it in park & neutral)
Or has wire from the key fallen off the starter solenoid?
If it hasnt then stick a screwdriver across the larger positive terminal (from the battery) to the spade terminal (easier with small spade wire removed) on the starter solenoid.
If it spins over then back track to the inhibit switch & ingintion switch.
Auto doesnt need earth as its bolted to the motor
Good luck
Edited by LJ RB30, 08 May 2017 - 11:45 AM.
#4 _TheGatch_
Posted 08 May 2017 - 04:12 PM
Cheer for input
#5 _TheGatch_
Posted 08 May 2017 - 04:25 PM
Posted 08 May 2017 - 04:43 PM
Step 2: Buy a multimeter.
Check for 12v at the starter solenoid.
Confirm wiring continuity from solenoid to ignition switch.
The purple wire is your friend.
Posted 08 May 2017 - 04:45 PM
it will still start , but should have one for safety reasons
like if its left in drive the car will start and then take off
#8 _TheGatch_
Posted 08 May 2017 - 06:50 PM
#9 _TheGatch_
Posted 11 May 2017 - 10:00 PM
Posted 07 June 2017 - 07:44 PM
