LC/J steering rack.
Posted 14 May 2017 - 09:06 PM
Page 278, item 25, shows a spring as listed on page 279. This spring pushes the rack yolk into mesh with the pinion.
Mine has 1 concaved/convex spring washer in this area.
Wear marks indicate that there should be 2 opposed washers?
Part No. VS11203
Just want to know if it is indeed a single spring or concaved spring washers?
Posted 14 May 2017 - 09:46 PM
So my suspicions were correct. Thank you!
Posted 14 May 2017 - 09:51 PM
Posted 14 May 2017 - 09:56 PM
This rack is a "prototype" rebuild as parts were missing (see above) and some shims had been removed and discarded along the way. I have had to cut 2 shims so far.
This rack is out of my car which is off the road.
It will be fitted to a mates car whose rack has "issues" as well.
Edited by rodomo, 14 May 2017 - 09:57 PM.
Posted 15 May 2017 - 10:26 AM
Edited by RallyRed, 15 May 2017 - 10:27 AM.
Posted 15 May 2017 - 11:41 AM
Had two done last week.
Always come out perfect.
Posted 15 May 2017 - 06:58 PM
Ta..can you PM me the details, if you choose....thanks
#9 _Agent 34_
Posted 15 May 2017 - 07:29 PM
I need a company as well once i get the replacement one
Posted 15 May 2017 - 08:21 PM
Nothing wrong with mine (I think) Grant..but like all? these old things, you get that degree or so of play each side of centre when sitting in the shed.( i.e. steering wheel turns, wheels dont)
I sometimes ponder if that is correct...
Edited by RallyRed, 15 May 2017 - 08:21 PM.
Posted 22 May 2017 - 11:10 PM
Posted 29 May 2017 - 09:12 AM
I would be keen to see how you go. Mines pretty tight but could always be better.
Posted 31 May 2017 - 10:22 PM
So this rack was fitted but it wont self centre properly. I have modified the left rack end bush to accept an available bush but it's too tight.
I'll tighten up the exchange rack and refit it then play more with this mod.....................That could take a month or 2.
What I have learned is the manual specs are merely a guide on these old racks.
Posted 01 June 2017 - 06:46 AM
Good info..thanks
Posted 01 June 2017 - 12:39 PM
Don't know about LJ/LC but I just got a changeover rack for the LX from Super Steer (Wonga Park) Melbourne. He does a lot of old cars and wouldn't surprise if he does LJ/LC. Cheers Ron
Posted 05 June 2017 - 03:28 PM
Sorry for not following up guys,
bloke is in Toongabbie, just keep forgetting to grab the card from the desk at the shop
#17 _Agent 34_
Posted 06 June 2017 - 06:25 AM
Turner drivershafts in brookvale - just did one for me
Posted 11 October 2017 - 11:01 PM
The shop manual is also incorrect re this part and other bits too.I have the parts manual but cant post a pic from it.
Part No. VS11203
