when sanding gelcoat off of flare kit what is good to sand with [i mean what graded paper] and wet or dry ?
i will epoxy then absinth yellow colour or do i use high build as well ?
Posted 26 May 2017 - 06:27 AM
Posted 26 May 2017 - 08:56 AM
Posted 26 May 2017 - 12:17 PM
arh yes so true, sorry not sand off though
to take the shine off it so the epoxy will stick to it
Posted 26 May 2017 - 07:32 PM
Well if your not sanding through the gellcoat then you dont really need epoxy.
And if they dont have any imperfections that need addressing then they dont need high fill either.
Either way high fill will only be needed if its needed.
I would chop the gelcoat with 180 dry and a semi flexi block and see what it looks like after that, if there are lots of shiny spots left (low spots) or you block through the gelcoat (high spots) or more likely both then go the epoxy over the raw glass and high fill route (after scuffing the shiny bits.)
Or if they look to be in real good shape just hit them with a maroon (coarse) or green (medium) scotch brite pad. Probably a coat of primer/surfacer, another scuff and top coat.
As always, its impossible to give you a step by step guide without actually holding the parts in my hand and anyone who tries is just blowing smoke.
Your first step will be to check them out REALLY closely and see where you think they should go from there.
Posted 27 May 2017 - 12:00 AM
Posted 27 May 2017 - 12:44 AM
Eh, I try.
Take it or leave it, i just try to say how I would go about something, anything thats not clear ask again with some more detail and I will try again hahaha.
Posted 27 May 2017 - 06:30 AM
thanks i love and appreciate your advice
the wheel flares are good but the front spoiler weve have to cut and reglass and as i was bending passenger side around to meet wheel flare i craked spoiler oops! so a few repairs have been needed and chips was told from posting ?
all good cheers
Posted 29 May 2017 - 05:18 PM
