Inlet manifold corrosion repairing info
6 replies to this topic
#1 skywalker
skywalker
  • 24 posts
  • Name:Luke
  • Car:LX Torana
Posted 27 May 2017 - 01:14 PM
Hey all,
looking for somebody in melb area that can weld/repair mill out corroded inlet manifold,
issues are,
corrosion at the top where housing sits,
thermostat step down needs reworking,
some body tapped out the housing threads & used metric bolts,
haven't pulled it off yet,may have more corrosion on the side face,
TIA
#2 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 27 May 2017 - 03:20 PM
For what it's gonna cost you might as well look for a better one.
#3 skywalker
skywalker
  • 24 posts
  • Name:Luke
  • Car:LX Torana
Posted 27 May 2017 - 07:00 PM
How much do you roughly think a good one will cost
Edited by skywalker, 27 May 2017 - 07:01 PM.
#4 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 28 May 2017 - 12:10 AM
The last stock 308 intake I sold was in very good condition and went for $80.
#5 Bigfella237
  • 4,373 posts
Posted 28 May 2017 - 12:43 PM
Once you get the manifold off you will likely find that it's also corroded around the four water jackets where it meets the heads too, very common problem. Sometimes they get so bad as to leak coolant into the valley (which obviously ends up in the sump).
I've repaired a few of them myself over the years, just clean it up with a die grinder, fill it (fillet?) with a TIG up proud of the surface and then just carefully file it back flush.
Might be a bit harder around the thermostat opening, you'd probably require a mill to restore the lip that the thermostat sits in, but I guess it could be done by hand as well if careful?
These days it's probably only worth doing if you want to retain a "numbers matching" engine assembly, otherwise as Rexy says, just replace it?
#6 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 30 May 2017 - 10:28 PM
Hey all,
If you're prepared to come down to Geelong I had Johnny Dyno weld mine up.  It was in really bad shape in all the usual places but cost about $200.  I guess you could get a good uncorroded one for that kind of money though, but the issue is where are the uncorroded ones.
#7 skywalker
skywalker
  • 24 posts
  • Name:Luke
  • Car:LX Torana
Posted 01 June 2017 - 09:31 PM
Thanks for that info bud, I'll keep that in mind.
