Wow thats heaps. No stress but as I'm leaning towards making something up. I dont have the gear to do so but have people that do. Are you from aroind this area?
I'm only a couple of hundred kays from you, up at Boyup Brook.
Posted 13 January 2020 - 09:03 AM
Posted 04 February 2020 - 11:44 AM
Posted 04 February 2020 - 12:06 PM
If you find one with an uncut coin tray, I will swap you for one with a radio hole.
Posted 04 February 2020 - 12:12 PM
Will do. I dont have the funds to pay for an uncut one.If you find one with an uncut coin tray, I will swap you for one with a radio hole.
Posted 04 February 2020 - 01:24 PM
Buy some epoxy and apply some creative plastering, a bit of paint and you'd never know
Posted 09 February 2020 - 08:12 PM
Posted 09 February 2020 - 08:29 PM
Posted 09 February 2020 - 08:41 PM
Hey mate. The rear seat mount is easy. Its is done from underneath. I'll put a pic up. Once i get under the car I'll seal the edges with morw sikalfex then coat in stone guard. Not going to spot weld it in spot. It wont be going anywhere when I'm done and i dont have a welder or the knowhow. Getting someone else to weld the rest for me.I am literally about to do this in my car aswell.
I was planning of doing from underneath but I may do it this way too it's been good seeing the way you have done it.
Nice work.
Are you going to spot weld the bracket in from ontop aswell though?
Sent from my SM-G965F using Tapatalk
Posted 09 February 2020 - 09:06 PM
Posted 09 February 2020 - 09:14 PM
Posted 09 February 2020 - 10:08 PM
Posted 09 February 2020 - 11:06 PM
~ Does it have to be engineered seeing as though our cars didn't come with the bucket seats?
It's a bit of a grey area as bucket seats were a factory option for that model, however it boils down to altering the seating capacity as indicated by the compliance plate, so yes.
Posted 10 February 2020 - 08:15 AM
Not gray at all. If it’s a factory option (and you do it with factory bits) it is clearly ok.
Replicating the factory option with non factory bits has never needed engineering when I have asked.
Posted 10 February 2020 - 09:14 AM
Sent from my SM-G970F using Tapatalk
I'm not sure on W.A regulations but on the East coast a blue plate is required because you are changing the seating capacity .
No certifying engineer would pass that seat mount , & no engineer should !
The corners should be radiused 25mm & ALL edges should be radiused also. This is to prevent the plate tearing the floor during an impact .
Depending on the certifier you may also need to fully weld the nut. This is to stop moisture getting in & rusting the welds <sic> out from the inside .
Sikaflex is not a substitute for welding.
Posted 10 February 2020 - 09:15 AM
As I alluded to earlier, bench seat cars have "SEATING CAP. 6" on the Compliance Plate.
If you change to bucket seats the car no longer has 6 seating positions (assuming you also fit a centre console), therefore it no longer complies and requires an engineer to sign-off on the altered seating capacity.
EDIT: DOH! Col beat me to it.
Edited by Bigfella237, 10 February 2020 - 09:16 AM.
Posted 10 February 2020 - 09:34 AM
But is it safe?
Or are you just trying to flex your knowledge?
If you're using a standard Torana front seat, for example, I am quite confident that the spot welds on the seat frame or the mounts on the seat frame will fail before that load spreading plate tears through the floor.
I can see a few ways to make this plate solution a stronger one, of course. But "over engineering" is not engineering, and it's particularly pointless if it is not the weakest link anyway.
Also, a factory Torana bench seat car was considered adequately safe at the time (eg. in an accident where someone runs up your arse) with the mass of 3x adults across the front seat, using only four mounts in total.
This car will have 1x adult on each seat, each seat connected to the floor with four mounts.
Edited by Heath, 10 February 2020 - 09:39 AM.
Posted 10 February 2020 - 09:56 AM
Posted 10 February 2020 - 10:40 AM
Posted 10 February 2020 - 12:55 PM
It’s the same as converting a factory 6 cylinder LH/LX to V8 using factory bits. This has never needed engineer sign off in Victoria.
They have the common sense to ignore that the car is now “different” to delivery and recognise it is a reasonable change. No one cares what’s on the build plates.
You know what else didn’t need engineering sign off every time I asked Vicroads?
9 inch diff or gearbox conversions.
Now if only we had SA owner certified modification approval and their ability to re register their same owner expired registration cars we would be perfect!
Gene, you are welcome In Mexico any time you want to make the move!
Posted 10 February 2020 - 02:19 PM
Posted 29 March 2020 - 09:22 PM
Edited by bags, 29 March 2020 - 09:24 PM.
Posted 29 March 2020 - 09:41 PM
Posted 30 March 2020 - 06:05 AM
I used the VHT product 21 years ago in my LJ, still looks good.
Posted 13 April 2020 - 09:19 AM
Posted 13 April 2020 - 09:51 AM
That roof lining has come up a treat. I have heard of brown factory carpet being painted black with it as well.
