73 heater box modification
12 replies to this topic
#1 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 July 2017 - 07:38 PM
Hi all, in particular Dave, I'm hoping that someone can post up some photos of the heater box mod gmh did to fix the cable bind I've heard of, my friend is playing around with his heater mechanisms atm & would a description of the mods done please, looking forward to the replies, Gary.
#2 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 04 July 2017 - 08:29 PM
If its any help.Marty beefed up to a thicker
guage wire to stop it from bending.
Im putting my box in as i speak and
Faaaaaark me ,trying to put cable on to
the dr flap mechanism took some doing .lyimg
on back with handbrake digging in you all
cramped up....
Lost 2 nuts down the back of the vinyl
flooring..they're frOcking staying there..
#3 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 July 2017 - 09:59 PM
Hi Gary, I got some wire from a lawn mower shop, it was slightly thicker than genuine but still fitted the sheath.  Made up a jig for bending the wire to look original and it works way better than expected.
I'll see if I can find the link to thread.
Marty
#4 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 July 2017 - 10:01 PM
http://www.gmh-toran...j-heater-cable/
See if that works
#5 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 05 July 2017 - 10:38 PM
All good Marty, can you please tell me what you actually did to the cam on the heater set up (modification wise) thanks for the thread input. Gary.
#6 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 July 2017 - 11:45 PM
This is all I have,  can't remember what corners I filed but its' easy to work out.
http://www.gmh-toran...box-setup-mods/
You can see the difference in the #2 reply in the bottom 2 pictures.
Edited by sibhs, 05 July 2017 - 11:47 PM.
#7 S pack
  • 15,539 posts
Posted 06 July 2017 - 07:50 AM
I'll email you tonight Gary. I'm not posting Dealer Service Letters on the forum anymore.
#8 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 06 July 2017 - 08:20 PM
No problem Dave thanks for your help, Gary.
#9 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 07 July 2017 - 08:14 PM
I did Marty's upgrade to the heater control cable recently and it was a big improvement over my old kinked cable. If you do this modification make sure that the loop you make on the ends is off to the same side as the tab for screws, otherwise you'll have to try to twist it around later.
I'd be interested to know what GMH did to improve the situation and when in 73 this came into effect, after July when my car was made I assume.
#10 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 07 July 2017 - 08:23 PM
Thanks again everyone, i think that i will do these mods to my heater box too, when the time comes to do it, Gary.
#11 S pack
  • 15,539 posts
Posted 07 July 2017 - 08:45 PM
The mod is kind of what Marty did but not so severe. November 1973 was when the modified parts went into production and the dealers were asked to check the control functions of customers cars as they came in for service and perform the modifications, if required, at no cost to the customer regardless of whether in or out of warranty. This was because the heater demist function is the requirement of an ADR.
#12 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 08 July 2017 - 08:55 AM
I sympathise with the unfortunate mechanic's that got lumped with having to remove and reinstall the heater boxes.
#13 S pack
  • 15,539 posts
Posted 08 July 2017 - 09:04 AM
^^^ lol, I'd rather R & R an LC/LJ heater box than perform any major repair works in the engine bay of most late model compact front wheel drives.
