Engine bay skirt removal
5 replies to this topic
#1 mattie304
mattie304
  • 27 posts
  • Car:LX 4 door
Posted 07 July 2017 - 05:05 PM
Need to R&R the engine bay skirts on LX.
Car atm is on rotisserie only bare shell.
My question is will it move and put each rail out if i un-pick on rotisserie.
Gut is telling me yes, but open to all on this one as don't wont to stuff up.
If any one has done before any tip would go a long way.
Not a noob , done floors, trans tunnel  just the skirts have me thinking its going to move.
 Thanks Matt
#2 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 08 July 2017 - 12:05 AM
If in doubt, then maybe on a flat cement floor with legs under the rails? Nice avatar by the way. I always wonder what happened to that motor.
#3 S pack
  • 15,539 posts
Posted 08 July 2017 - 09:15 AM
Whichever way you go I'd thoroughly document the work if you are removing & refitting the panel with the chassis number. Could save some unwanted speculation and insinuations in the future, esp if your LX is an 8VD69.
#4 mattie304
mattie304
  • 27 posts
  • Car:LX 4 door
Posted 08 July 2017 - 10:09 AM
Its only a SL,
Only doing the skirts as cut part of them out yrs ago for turbos.
Both front panels are good ( battery and chassis num side)
Already photoed
#5 LS1LX
LS1LX
  • 1,931 posts
Posted 03 August 2017 - 06:56 PM
If your really worried about movement/shifting make a brace and bolt it to the bottom side on the rails tie-ing the front together and take the front end weight off the rotisserie.
#6 _Liam_
_Liam_
Posted 23 August 2017 - 06:44 PM
Cut section about 200mm long (or shorter if concerned). Weld the skins together.  Go the next 200mm. Weld skins together.
​And so on and so forth, once completely welded, grind back and lay another bead on it all the way along again.  I'd recommend trimming the lip running along the rear of the firewall too.
