Oil for 138 big block
9 replies to this topic
#1 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 11 July 2017 - 10:37 PM
Hi guys.i want to drain oil out of my 138
which has done 110 thou miles..
What kind of olive oil should i use.. 15/50 ?
Was going to give her a detox but thought it
might do more damage than good cleaning
her right out..
Cheers maz
Edited by madtoranajzedded, 11 July 2017 - 10:44 PM.
#2 dattoman
  • 16,470 posts
Posted 11 July 2017 - 10:54 PM
Realistically
It doesn't have to be fancy
Valvoline XLD would be fine
And streets ahead of the oil that it left the factory with.
#3 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 12 July 2017 - 12:38 AM
Which one Datto.theres a few to choose..
Classic, premium both 20/50 or the 15/40
Just looking in the autobarn catalogue
they have a castrol gtx 15/50 for high
milage vehicles.Would this work just as
good as the valvoline.
Edited by madtoranajzedded, 12 July 2017 - 12:41 AM.
#4 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 12 July 2017 - 06:55 AM
I think you'll find that 15/50 will be a bit light unless it's a fresh engine, I generally use a 20/50 if the engine has been around the block a few times.
#5 Dr Terry
Dr Terry
  • 3,276 posts
Posted 12 July 2017 - 07:41 AM
Yeah, totally agree. I use 20W50 SN in all my early cars.
Dr Terry
#6 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 12 July 2017 - 06:28 PM
Hi Maz, For the smidgen of $ personally I'd at least put some nulon oil in it. & if you decide to use an engine flush, liquimoly in the grey tin i believe you can't go past. They also do a 20w 50 in full synthetic I'm pretty sure & it should be available through your autobarn ect or even some Fuchs. If your saw inside my engine after 294,000 klms regularly serviced you'd be convinced, but I'm just offering you all my thoughts. Gary.
#7 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 13 July 2017 - 01:02 PM
Thats the one i have grumps as in engine
flush but im abit hesitant to use it..
I ended up getting the valvoline xld but not
sn as went to only couple stores repco and
supercheap,clean forgotten about autobarn.
The only 20/50 in those store were gulf
wester nand castrol gtx but no sn.
#8 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 July 2017 - 07:01 PM
Hi Maz, all liquimoly products are brilliant, just let it idle for around 15 minutes & it should be fine. Don't drive it with it in unless the engine is really gummed up. You'll probably be surprised at the crap that comes out in the oil, it will most probably be black like a diesel oil. I've found autobarn stock the liquimoly oils in bigger quantity, super cheap are the cheapest for smaller bottles of it & are the cheapest for the nulon, repco have it on sale around every 3rd week. & nulon gearbox oils ect seem to be much easier to get online atm. & Bursons seem to be the main stockist of Fuchs oils, Gary.
#9 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 13 July 2017 - 07:48 PM
Ahh.bugger done it bout 1 1/2 ago.
Just drained new oil,filter etc.well altleast
I know and everybody else what to do.
Oil was black as.i even have more oil
pressure now bout 9psi more and now reads 40
Thats with a good 20 min drive..will b
taking out lifters nxt couple pushrods theres
no oil getting up into head so ill b asking
how to do them and tappet adjustment soon
Cheers maz
#10 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 July 2017 - 11:50 PM
I'd guess the other guys might suggest that you use a ultrasonic cleaner for the pushrod cleaning, or even some light gauge .6 ect mig wire & a cleaner. I presume that you are reusing the pushrods ? Don't be surprised if the lifters are gummed in & difficult to remove though. Ask about what the other guys use for a lube on the base of the new lifters, i would have soaked them in a bag of 30 weight oil and lubed the bottoms with some molybdenum disulfide (moly grease) but there may be a better idea around. Gary.
