LH with 19 inch VE SS rims
4 replies to this topic
#1 _joshua626262_
_joshua626262_
Posted 17 July 2017 - 08:48 PM
Hi guys,
Just wondering what I need to do the get these rims to fit? I am going to get a vn borg Warner diff shortened just wondering do I shorten to the standard torana width? what offset do I need?
Josh
#2 dattoman
  • 16,471 posts
Posted 17 July 2017 - 09:20 PM
If thats the wheel you really want Borrow one... then try it on all 4 corners and measure... alot
Due to the FWD style offset that Commodore wheels have... you'll have to do alot of measuring and figuring to get them to fit
The will likely foul the firewall also
14mm studs too.
#3 ozyozyozy
ozyozyozy
  • 944 posts
Posted 17 July 2017 - 10:15 PM
Would need to widen hubs and diff to make them fitz
Also give the car 4wd ride height for enough clearance for suspension/steering.
#4 Heath
  • 18,314 posts
Posted 17 July 2017 - 10:26 PM
I sometimes try and keep my opinions to myself, but normally not too hard. That would be truly tasteless, and would be a shame to go to the effort of setting up wider hubs and a longer diff to accomodate for the pissweak offset, because it just makes it so much harder to reverse it back to looking decent when you come to your senses.
#5 gtrboyy
gtrboyy
  • 3,137 posts
Posted 17 July 2017 - 11:12 PM
The commodore wheels practically engulf control arms & sit in bit too far,either need custom hubs or much frowned upon spacers.
You're fairly limited in choice of wheels with commodore stud pattern compared to what's on offer with hq/chev pattern which has better variety & availability of wheels
