Clutch Kit LC-LJ
L:C - LJ Clutch
9 replies to this topic
#1 ChrisLC
ChrisLC
  • 100 posts
  • Name:Chris
  • Car:1971 LC Four Door S
Posted 20 July 2017 - 04:15 PM
Hi all,
Re clutch kits, what is the go these days? What's OK and not so OK? Are HCB any good or is Excedy better? I currently run a one-tonner in my six cylinder LC, but motor is getting rebuilt, may as well throw a new clutch in. I know in the past the XU-1 clutch was damn heavy, whereas the one-tonner feels lighter.
Look forward to your help.
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 20 July 2017 - 06:15 PM
Speaking personal preference only, i like the xtreme clutch. That's what I'll be running, have 1 in my t56 daily, brilliant to drive with my ss has a exedy & it won't be replaced with an exedy, if that explains my thoughts on them. Or you could get a npc clutch.
#3 _duggan208_
_duggan208_
Posted 21 July 2017 - 01:17 AM
I use an AP not as heavy as one might think, my 6 will never bust it. Regards
#4 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 21 July 2017 - 06:42 AM
Have run an Xtreme in the past and was happy with it. I run a clutch industries heavy duty at the moment and it does not slip.
#5 warrenm
warrenm
  • 2,106 posts
  • Car:1972 LJ Torana
Posted 21 July 2017 - 07:59 AM
I see your are in Sydney, give John or Scott at Western Clutches a call 02 96231233, he'll more than likely supply a clutch that suits for less money that at most parts stores.
Edited by warrenm, 21 July 2017 - 08:08 AM.
#6 ChrisLC
ChrisLC
  • 100 posts
  • Name:Chris
Posted 21 July 2017 - 11:22 AM
Thank you all, very helpful.
#7 ChrisLC
ChrisLC
  • 100 posts
  • Name:Chris
Posted 21 July 2017 - 11:36 AM
Another question, running the XU1 type or the one-tonner type? I am still running original rat trap linkages and don't want to start breaking linkages (again).
#8 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 21 July 2017 - 06:18 PM
Xu1 type mate, i think a lot of issues in the breakages can be due to incorrect adjustment or worn linkages & parts. I've set them up to factory settings, with good condition parts in the past & it makes a world of difference. Gary.
#9 S pack
  • 15,538 posts
Posted 21 July 2017 - 06:32 PM
Most failures are due to worn parts. Regular lubrication, esp if the car is a daily can help the parts to live. Biggest problem is the pull rod from the pedal to the relay lever. No amount of regular maintenance will prevent one of the bullet heads at either end of the rod from suffering a fatigue failure. And for anyone that is interested the pull rods on the HT/HG Holden are no stronger in their construction than the LC/LJ's.
#10 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 21 July 2017 - 07:09 PM
Thanks Dave !
